I am using a dual tuner ota hauppauge usb device with next pvr to feed into channels dvr on win11 pro. I have more but want to get 2 streams working first. If I record 1 ota show, I cannot watch (or record) a different channel. Next pvr sees both tuners, but I don't think channels dvr does. I have tried setting different stream limits, but it doesn't help. I think I must have something configured wrong, but the 1 stream works pretty well. please advise.
You'll need to provide more detail on how you have this set up. For example the specifics of the CDVR Custom Channels Source you've configured, and the CDVR log lines related to both your initial and subsequent tunes.
Support - Logs in the V1 interface you're using.
I'm sorry, you're a tech genius , and I am not. V1 interface?
The Channels DVR admin UI you're using (shown in the screenshot you posted). It's been updated recently to version 2, but I can.see you're on version 1. I mention that because it matters as far as where to find the logs.
OK thank you. yes I'm on version 1. Where would I find the logs? would v2 be better?
There may be some setting on the nextpvr side. Channels will just use the streams published in the m3u
Use the Support menu item, and select Logs. Just post the log lines related to a successful tune, and then a failed tune when you try to tune a second OTA channel from NextPVR.
2026/11/19 11:03:40.516644 [TNR] Closed connection to M3U-nextPVR for ch5.1 KXAS-HD
2026/11/19 11:03:40.550802 [HLS] ffmpeg: ch5.1-dANY-ip127.0.0.1-remux: [in#0/mpegts @ 0000017e4ffc3dc0] could not find codec parameters
2026/11/19 11:03:40.550802 [HLS] ffmpeg: ch5.1-dANY-ip127.0.0.1-remux: Error opening input file -.
2026/11/19 11:03:40.550802 [HLS] ffmpeg: ch5.1-dANY-ip127.0.0.1-remux: Error opening input files: End of file
2026/11/19 11:03:40.552905 [HLS] Couldn't generate master playlist for ch5.1-dANY-ip127.0.0.1: stream stopped
2026/11/19 11:03:40.552905 [HLS] Stopping transcoder session ch5.1-dANY-ip127.0.0.1 (out=0s finished=true first_seq=0 last_seq=-1)
2026/11/19 11:03:40.552905 [ERR] Probe cancelled for live stream after 36.2605ms and 0 bytes
2026/11/19 11:03:40.732674 [TNR] Opened connection to M3U-nextPVR for ch4.1 KDFW-DT
2026/11/19 11:03:40.732674 [DVR] Recording for job 1795107804-ch4.1 from M3U-nextPVR ch4.1 into "TV\Live with Kelly and Mark\Live with Kelly and Mark S05E52 2026-11-19-1103.mpg" for 56m19.9661565s
I set ch 4.1 to record, that started. then I tried to tune to 5.1 without success.
It doesn't look to me like NextPVR delivered a second stream. Have you looked in the NextPVR logs to see if there are any clues there?
Yes, nextpvr generates multiple logs, and I don't know what I am looking at, or looking for. This is above my paygrade. Thanks for trying. Do you think I would have better luck with VLC as ota input?
You could try using VLC as a client (much as you're doing with CDVR), to see if you can play two streams simultaneously using two instances of VLC. That would confirm the problem is on the NextPVR side.
I just tested nextpvr by recording one channel and watching a 2nd, and it works. Do I have to maybe set up a 2nd tuner in Channels dvr and specify 2 different inputs? If so how would I differentiate them. Nextpvr has them indentified as tuners #0 and #1.
It seems some issue with nextpvr
Someone said it works fine with tvheadend
I think tv headend is just for linux, I'm on windows.
OK, I'm pretty sure i got it working! In nextpvr-settings-devices, scan for tuners.Then scan channels on 1st ATSC tuner, skip guide setup, and save. Click on next tuner, and assign same channels to the tuner. I have a thrid, so I did that again. Then in NextPVR -settings-channels, click on "merge by" and choose numbers or names, I don't think it matters. In channels dvr source setup, add 1 source for each tuner. I named mine NextPVR 0, 1 and 2. Add "&client=tuner0" to your url after m3u. Repeat for tuner1, and tuner 2 for subsequent sources. This worked for me!
