Having problems after moving DVR service
I’m not quite sure what I did wrong. But I can see my recordings after doing a restore, however they will not play. Plus I can not record. Any clues to what may be wrong? I pulled the drive from the old system and put it in an external case. It is hooked up via USB 3.0. Here is the log from trying to record Walking Dead:
910-ch731 The Walking Dead on ch=[731]
2017/11/05 20:55:57 [DVR] Waiting 3m32.525228s until next job 1509933570-12 The Walking Dead
2017/11/05 20:55:57 [TNR] Opened connection to 1314B16A for ch731
2017/11/05 20:55:57 [TNR] Closed connection to 1314B16A for ch731
2017/11/05 20:55:57 [DVR] Error running job 1509929910-ch731 The Walking Dead: CreateFile D:\DVR: The system cannot find the path specified.
2017/11/05 20:56:27 [DVR] Starting job 1509929910-ch731 The Walking Dead on ch=[731]
2017/11/05 20:56:27 [DVR] Waiting 3m2.0182023s until next job 1509933570-12 The Walking Dead
2017/11/05 20:56:28 [TNR] Opened connection to 1314B16A for ch731
2017/11/05 20:56:28 [TNR] Closed connection to 1314B16A for ch731
2017/11/05 20:56:28 [DVR] Error running job 1509929910-ch731 The Walking Dead: CreateFile D:\DVR: The system cannot find the path specified.
2017/11/05 20:56:58 [DVR] Starting job 1509929910-ch731 The Walking Dead on ch=[731]
2017/11/05 20:56:58 [DVR] Waiting 2m31.4930263s until next job 1509933570-12 The Walking Dead
2017/11/05 20:56:58 [TNR] Opened connection to 1314B16A for ch731
2017/11/05 20:56:58 [TNR] Closed connection to 1314B16A for ch731
2017/11/05 20:56:58 [DVR] Error running job 1509929910-ch731 The Walking Dead: CreateFile D:\DVR: The system cannot find the path specified.
2017/11/05 20:57:29 [DVR] Starting job 1509929910-ch731 The Walking Dead on ch=[731]
2017/11/05 20:57:29 [DVR] Waiting 2m0.9972047s until next job 1509933570-12 The Walking Dead
2017/11/05 20:57:29 [TNR] Opened connection to 1314B16A for ch731
2017/11/05 20:57:29 [TNR] Closed connection to 1314B16A for ch731
2017/11/05 20:57:29 [DVR] Error running job 1509929910-ch731 The Walking Dead: CreateFile D:\DVR: The system cannot find the path specified.
2017/11/05 20:57:59 [DVR] Starting job 1509929910-ch731 The Walking Dead on ch=[731]
2017/11/05 20:57:59 [DVR] Waiting 1m30.4869982s until next job 1509933570-12 The Walking Dead
2017/11/05 20:58:00 [TNR] Opened connection to 1314B16A for ch731
2017/11/05 20:58:00 [TNR] Closed connection to 1314B16A for ch731
2017/11/05 20:58:00 [DVR] Error running job 1509929910-ch731 The Walking Dead: CreateFile D:\DVR: The system cannot find the path specified.
2017/11/05 20:58:30 [DVR] Starting job 1509929910-ch731 The Walking Dead on ch=[731]
2017/11/05 20:58:30 [DVR] Waiting 59.9660512s until next job 1509933570-12 The Walking Dead
2017/11/05 20:58:30 [TNR] Opened connection to 1314B16A for ch731
2017/11/05 20:58:30 [TNR] Closed connection to 1314B16A for ch731
2017/11/05 20:58:30 [DVR] Error running job 1509929910-ch731 The Walking Dead: CreateFile D:\DVR: The system cannot find the path specified.
2017/11/05 20:59:00 [DVR] Starting job 1509929910-ch731 The Walking Dead on ch=[731]
2017/11/05 20:59:00 [DVR] Waiting 29.4698194s until next job 1509933570-12 The Walking Dead
2017/11/05 20:59:01 [TNR] Opened connection to 1314B16A for ch731
2017/11/05 20:59:01 [TNR] Closed connection to 1314B16A for ch731
Also noticed I cannot stream using web GUI:
2017/11/05 22:12:31 [HLS] Starting transcoder for channel 10.1 (encoder=h264_mf, resolution=480, deinterlacer=blend, bitrate=1000)
Could not write header for output file #0 (incorrect codec parameters ?): No such file or directory
Error initializing output stream 0:0 –
[aac @ 00000000024ef980] 2 frames left in the queue on closing
2017/11/05 22:12:41 [WRN] Buffer for 1042FD6C ch10.1 is more than 50% full (clients=1, len=16777684)
2017/11/05 22:12:46 [WRN] Buffer for 1042FD6C ch10.1 is more than 75% full (clients=1, len=25167184)
2017/11/05 22:12:50 [WRN] Buffer for 1042FD6C ch10.1 is more than 95% full (clients=1, len=31881416)
2017/11/05 22:12:51 [WRN] Buffer for 1042FD6C ch10.1 is more than 99% full (clients=1, len=33219788)
2017/11/05 22:13:33 [HLS] Stopping transcoder session ANY-ch10.1 @ 0s
2017/11/05 22:13:33 [TNR] Closed connection to 1042FD6C for ch10.1
Is d:\dvr the correct location for where your recordings are? If not, uncheck the DVR checkbox and fix the path.
Yes it is correct. Went upstairs to check system and noticed the D: drive didn’t show up. Restarted the external drive and all is working again. Thanks!
