HBOMax and Hulu sports?
Is there a method to include the live sports that are available on HBOMax and/or Hulu? (I understand one can use TVE for Hulu+LiveTV, but this is only for the sports that are on, e.g., periodic NHL games.)
I would really prefer to avoid ADBTuner and CC4C.
probably not as their m3us are DRMed..... so streamlinks and/or ADBtuner/CC4C is just the reality of the DRM world.
Can you point me to an ELI5 for ADB Tuner/CC4C?
If you are ok with streamlinks opening another app outside channels, check out FruitDeepLinks. new project I've been working on. basically, it creates a M3U/XML of sporting events to show up in your guide. When you click on event, it'll open the appropriate app to stream it.
initial ADB support has been added, and chrome capture coming later-- if you want to stay inside channels app.
