I'm suddenly getting advertisements for HDHome run prime jumping in to my Ota programs that I am watching real time. what is going on with that. then after the advertisement the signal goes dead and I get a lost signal error message
You will need to contact [email protected] with your HDHR device ID.
You should only be seeing this on demo Premium TV channels which are not received OTA.
ok thanks, are these demo channels color coded in the guide?
Yes they are. You can disable them by going into the settings section of the app so they don't appear anymore.
the hdhr app correct?.
ok never mind. I think I found the switch to turn off the HDHR premium channels
