HD Home Run Channels DVR
I thought if paid for the Channels DVR service i can record on the HRHD . It doesn't give me a option to record on the OTA channels. I'm using the HDHome Run Flex . Do i need a different one?
Thanks
On the DVR web UI on your Mac you need to set your zipcode under your HDHomeRun to download the guide data. Once that's downloaded the record options will appear in the app.
Note that the Channels DVR software can only record on your Mac, not on the HDHR Flex USB.
Got it working . Thanks So much
