I had a strange situation develop with a football game I recorded two weeks ago using Channels DVR software and my HD Homerun 4K ASTC 3.0 tuner. I assumed the game would be recorded off the local ABC channel which has the virtual number 3.1, but instead the game was recorded off the ASTC 3.0 channel for that station which has the number 103.1.
The recording plays back fine if you use the Channels software, but if I copied the file to another location to edit out the commercials, no sound was heard on VLC Player, Windows Media Player or the Movies and TV app on windows 11. Video was still perfect. I then remembered that I had also recorded the game on the seperate HD Homerun software, but it was also recorded from channel 103.1 and had the same audio problem. It played back fine using the HD Homerun software, but had no audio if you tried to play it back by other means.
This experience caused me to go back and disable ASTC 3.0 channels on the HD homerun software as well as Channels DVR to ensure this problem does not happen again.
I had the software to record games from my team on All channels, so I would never miss a televised game, but I need sound on my recordings, so I removed the ASTC 3.0 channels from my list.
By the way, the local channel is not encrypted, but there must be some DRM component that is causing this problem.
Has anyone else experienced this?
