I am new to the whole Hd Homerun and Channels Dvr. So yesterday I was recording Suits on USA Network and when I was watching the recording I noticed a few things. Like the play back was stuck playing the samething over and over. I had to fast forward to skip that spot, but there was other issues. When I looked at the log I saw that the channel keeper timing out. What would cause this? Here is the log for the suits recording.
2018/09/19 22:59:00 [DVR] Starting job 1537415940-22 Suits on ch=[1403]
2018/09/19 22:59:00 [TNR] Opened connection to 10740D22 for ch1403
2018/09/19 22:59:00 [DVR] Recording for job 1537415940-22 from 10740D22 ch1403 into āTV/Suits/Suits S08E10 2018-09-19 Managing Partner 2018-09-19-2259.mpgā for 1h1m59.996002506s
2018/09/19 23:16:07 [NAT] Successfully mapped port 8089 using natpmp
2018/09/19 23:30:39 [DVR] Cancelling stream 10740D22 ch1403 after 3s read timeout
2018/09/19 23:30:39 [TNR] Closed connection to 10740D22 for ch1403
2018/09/19 23:30:39 [DVR] Job 1537415940-22 Suits ended prematurely: 30m20.604164006s
2018/09/19 23:30:39 [DVR] Starting job 1537415940-22 Suits on ch=[1403]
2018/09/19 23:30:40 [TNR] Opened connection to 10740D22 for ch1403
2018/09/19 23:30:40 [DVR] Recording for job 1537415940-22 from 10740D22 ch1403 into āTV/Suits/Suits S08E10 2018-09-19 Managing Partner 2018-09-19-2259.mpgā for 30m20.600497619s
2018/09/19 23:30:54 [DVR] Cancelling stream 10740D22 ch1403 after 3s read timeout
2018/09/19 23:30:54 [TNR] Closed connection to 10740D22 for ch1403
2018/09/19 23:30:54 [DVR] Job 1537415940-22 Suits ended prematurely: 30m5.79329918s
2018/09/19 23:30:54 [DVR] Starting job 1537415940-22 Suits on ch=[1403]
2018/09/19 23:30:54 [TNR] Opened connection to 10740D22 for ch1403
2018/09/19 23:30:54 [DVR] Recording for job 1537415940-22 from 10740D22 ch1403 into āTV/Suits/Suits S08E10 2018-09-19 Managing Partner 2018-09-19-2259.mpgā for 30m5.78714709s
2018/09/19 23:31:08 [DVR] Cancelling stream 10740D22 ch1403 after 3s read timeout
2018/09/19 23:31:08 [TNR] Closed connection to 10740D22 for ch1403
2018/09/19 23:31:08 [DVR] Job 1537415940-22 Suits ended prematurely: 29m51.024989001s
2018/09/19 23:31:08 [DVR] Starting job 1537415940-22 Suits on ch=[1403]
2018/09/19 23:31:09 [TNR] Opened connection to 10740D22 for ch1403
2018/09/19 23:31:09 [DVR] Recording for job 1537415940-22 from 10740D22 ch1403 into āTV/Suits/Suits S08E10 2018-09-19 Managing Partner 2018-09-19-2259.mpgā for 29m51.021286531s
2018/09/19 23:31:23 [DVR] Cancelling stream 10740D22 ch1403 after 3s read timeout
2018/09/19 23:31:23 [TNR] Closed connection to 10740D22 for ch1403
2018/09/19 23:31:23 [DVR] Job 1537415940-22 Suits ended prematurely: 29m36.248341549s
2018/09/19 23:31:23 [DVR] Starting job 1537415940-22 Suits on ch=[1403]
2018/09/19 23:31:24 [TNR] Opened connection to 10740D22 for ch1403
2018/09/19 23:31:24 [DVR] Recording for job 1537415940-22 from 10740D22 ch1403 into āTV/Suits/Suits S08E10 2018-09-19 Managing Partner 2018-09-19-2259.mpgā for 29m36.242638257s
2018/09/19 23:31:38 [DVR] Cancelling stream 10740D22 ch1403 after 3s read timeout
2018/09/19 23:31:38 [TNR] Closed connection to 10740D22 for ch1403
2018/09/19 23:31:38 [DVR] Job 1537415940-22 Suits ended prematurely: 29m21.474600375s
2018/09/19 23:31:38 [DVR] Starting job 1537415940-22 Suits on ch=[1403]
2018/09/19 23:31:39 [TNR] Opened connection to 10740D22 for ch1403
2018/09/19 23:31:39 [DVR] Recording for job 1537415940-22 from 10740D22 ch1403 into āTV/Suits/Suits S08E10 2018-09-19 Managing Partner 2018-09-19-2259.mpgā for 29m21.470957199s
2018/09/19 23:31:53 [DVR] Cancelling stream 10740D22 ch1403 after 3s read timeout
2018/09/19 23:31:53 [TNR] Closed connection to 10740D22 for ch1403
2018/09/19 23:31:53 [DVR] Job 1537415940-22 Suits ended prematurely: 29m6.715587454s
2018/09/19 23:31:53 [DVR] Starting job 1537415940-22 Suits on ch=[1403]
2018/09/19 23:31:53 [TNR] Opened connection to 10740D22 for ch1403
2018/09/19 23:31:53 [DVR] Recording for job 1537415940-22 from 10740D22 ch1403 into āTV/Suits/Suits S08E10 2018-09-19 Managing Partner 2018-09-19-2259.mpgā for 29m6.711873242s
2018/09/19 23:32:08 [DVR] Cancelling stream 10740D22 ch1403 after 3s read timeout
2018/09/19 23:32:08 [TNR] Closed connection to 10740D22 for ch1403
2018/09/19 23:32:08 [DVR] Job 1537415940-22 Suits ended prematurely: 28m51.964401088s
2018/09/19 23:32:08 [DVR] Starting job 1537415940-22 Suits on ch=[1403]
2018/09/19 23:32:08 [TNR] Opened connection to 10740D22 for ch1403
2018/09/19 23:32:08 [DVR] Recording for job 1537415940-22 from 10740D22 ch1403 into āTV/Suits/Suits S08E10 2018-09-19 Managing Partner 2018-09-19-2259.mpgā for 28m51.960654344s
2018/09/19 23:32:22 [DVR] Cancelling stream 10740D22 ch1403 after 3s read timeout
2018/09/19 23:32:22 [TNR] Closed connection to 10740D22 for ch1403
2018/09/19 23:32:22 [DVR] Job 1537415940-22 Suits ended prematurely: 28m37.204351315s
2018/09/19 23:32:22 [DVR] Starting job 1537415940-22 Suits on ch=[1403]
2018/09/19 23:32:24 [TNR] Opened connection to 10740D22 for ch1403
2018/09/19 23:32:24 [DVR] Recording for job 1537415940-22 from 10740D22 ch1403 into āTV/Suits/Suits S08E10 2018-09-19 Managing Partner 2018-09-19-2259.mpgā for 28m37.19899041s
2018/09/19 23:32:32 [DVR] Cancelling stream 10740D22 ch1403 after 3s read timeout
2018/09/19 23:32:32 [TNR] Closed connection to 10740D22 for ch1403
2018/09/19 23:32:32 [DVR] Job 1537415940-22 Suits ended prematurely: 28m27.087827656s
2018/09/19 23:32:32 [DVR] Starting job 1537415940-22 Suits on ch=[1403]
2018/09/19 23:32:38 [ERR] Failed to start stream on channel 1403 via 10740D22: Get http://192.168.1.44:5004/auto/v1403?: net/http: timeout awaiting response headers
2018/09/19 23:32:38 [DVR] Error running job 1537415940-22 Suits: could not start stream on channels=[1403]: Get http://192.168.1.44:5004/auto/v1403?: net/http: timeout awaiting response headers
2018/09/19 23:33:08 [DVR] Starting job 1537415940-22 Suits on ch=[1403]
2018/09/19 23:33:14 [ERR] Failed to start stream on channel 1403 via 10740D22: Get http://192.168.1.44:5004/auto/v1403?: net/http: timeout awaiting response headers
2018/09/19 23:33:14 [DVR] Error running job 1537415940-22 Suits: could not start stream on channels=[1403]: Get http://192.168.1.44:5004/auto/v1403?: net/http: timeout awaiting response headers
2018/09/19 23:33:44 [DVR] Starting job 1537415940-22 Suits on ch=[1403]
2018/09/19 23:33:50 [ERR] Failed to start stream on channel 1403 via 10740D22: Get http://192.168.1.44:5004/auto/v1403?: net/http: timeout awaiting response headers
2018/09/19 23:33:50 [DVR] Error running job 1537415940-22 Suits: could not start stream on channels=[1403]: Get http://192.168.1.44:5004/auto/v1403?: net/http: timeout awaiting response headers
2018/09/19 23:34:20 [DVR] Starting job 1537415940-22 Suits on ch=[1403]
2018/09/19 23:34:26 [ERR] Failed to start stream on channel 1403 via 10740D22: Get http://192.168.1.44:5004/auto/v1403?: net/http: timeout awaiting response headers
2018/09/19 23:34:26 [DVR] Error running job 1537415940-22 Suits: could not start stream on channels=[1403]: Get http://192.168.1.44:5004/auto/v1403?: net/http: timeout awaiting response headers
2018/09/19 23:34:56 [DVR] Starting job 1537415940-22 Suits on ch=[1403]
2018/09/19 23:35:02 [ERR] Failed to start stream on channel 1403 via 10740D22: Get http://192.168.1.44:5004/auto/v1403?: net/http: timeout awaiting response headers
2018/09/19 23:35:02 [DVR] Error running job 1537415940-22 Suits: could not start stream on channels=[1403]: Get http://192.168.1.44:5004/auto/v1403?: net/http: timeout awaiting response headers
2018/09/19 23:35:32 [DVR] Starting job 1537415940-22 Suits on ch=[1403]
2018/09/19 23:35:33 [TNR] Opened connection to 10740D22 for ch1403
2018/09/19 23:35:33 [DVR] Recording for job 1537415940-22 from 10740D22 ch1403 into āTV/Suits/Suits S08E10 2018-09-19 Managing Partner 2018-09-19-2259.mpgā for 25m27.052428752s
2018/09/20 00:01:00 [TNR] Closed connection to 10740D22 for ch1403
2018/09/20 00:01:00 [DVR] Finished job 1537415940-22 Suits
2018/09/20 00:01:00 [DVR] Processing file-43: TV/Suits/Suits S08E10 2018-09-19 Managing Partner 2018-09-19-2259.mpg
2018/09/20 00:01:01 [DVR] Running commercial detection on file 43 (TV/Suits/Suits S08E10 2018-09-19 Managing Partner 2018-09-19-2259.mpg)
2018/09/20 00:10:46 [DVR] Commercial detection finished with 10 markers.
2018/09/20 00:16:07 [NAT] Successfully mapped port 8089 using natpmp
2018/09/20 01:16:07 [NAT] Successfully mapped port 8089 using natpmp
2018/09/20 02:16:07 [NAT] Successfully mapped port 8089 using natpmp
2018/09/20 03:16:07 [NAT] Successfully mapped port 8089 using natpmp
2018/09/20 04:16:07 [NAT] Successfully mapped port 8089 using natpmp
2018/09/20 05:16:07 [NAT] Successfully mapped port 8089 using natpmp
2018/09/20 06:16:07 [NAT] Successfully mapped port 8089 using natpmp
2018/09/20 07:03:43 [TNR] Opened connection to 10740D22 for ch1113
2018/09/20 07:16:07 [NAT] Successfully mapped port 8089 using natpmp
2018/09/20 08:16:07 [NAT] Successfully mapped port 8089 using natpmp
2018/09/20 08:32:20 [DVR] Cancelling stream 10740D22 ch1113 after 3s read timeout
2018/09/20 08:32:20 [TNR] Closed connection to 10740D22 for ch1113
2018/09/20 08:33:20 [TNR] Opened connection to 10740D22 for ch1111
2018/09/20 08:33:26 [TNR] Opened connection to 10740D22 for ch1113
2018/09/20 08:33:26 [TNR] Closed connection to 10740D22 for ch1111
2018/09/20 09:16:07 [NAT] Successfully mapped port 8089 using natpmp
2018/09/20 09:20:18 [TNR] Closed connection to 10740D22 for ch1113
Any help would be great. Thank you in advance.
