HDHomeRun Mac (20250117beta1):
- Fix problem causing keychain security popup.
- New 7.1 surround sound audio support.
- Add support for MDU models.
- Drop "control master volume" option.
HDHomeRun RECORD (20250117beta1):
- Instantly fail operations when RecordPath is not set.
- Improvements to multithreaded operation.
HDHomeRun Firmware (20250117beta1):
- ATSC3: Fix problem handling 4K test broadcast from Canada.
- ATSC3: Fix problem where incorrect parental rating could be applied.
- TECH5/DEV: Fix problem with ATSC3 "forward" output format where power-save mode could activate stopping operation.
- TECH5: Auto-restart demodulation when needed on older ATSC1-only models.
- HDD models: Improve handling of a failing hard drive.
- UPnP: Only announce services using the primary IPv4 and primary IPv6 address.
- MDNS: Improvements to MDNS handling.
