I have the Raspberry PI4 channels dvr image and since Locast shutdown I bought and setup a HDHomeRun Flex 4k running latest Version 20210720. When I open the Beta(108.16.21.43) app on my Tivo Stream 4k and scan channels under source HDFX-4K it will find 23 channels but only 4 of the channels will play without giving playback failed message. Then every time I restart the channels app it will list only the 4 playable channels under source HDFX-4K until I rescan. I'm able to see all 23 channels just fine on the hdhomerun app on my pc. I ran a submit diagnostics. Please help.
On the dvr web UI, click the gear next to your HDHR and select Reload Lineup
You should also remove the Locast source by selecting the gear and clicking Remove
Thanks! When I logged in channels dvr server from phone I was able to get to the web UI and make these changes.
Every since I moved my server from my PC to my PI4 I'm no longer able to login to the server from my pc. Is there instructions you can point me to in order to fix this?
1st one worked 2nd one doesn't but I have what I need. Thanks again!
