Hdhomerun and unifi
Hi
Been using Chnnels for years with hdhomerun decided to go for a new network and got all unifi equipment now every time the hdhr is plugged in it kills the network even got a new hdhr and that did the same, been driving me nuts any help really appreciated
You'll need to be more specific and expand on that statement if you're looking for help.
Looks like you (or someone with the same issue) posted on the SiliconDust forum with more detailed information Strange issue with unifi ap - Silicondust
I have my HDHomerun plugged into my Cloud Gateway Ultra and have no issues.
Please list the symptoms you experience.
I have a pretty large unifi network for a home user. And 3 hdhr. I have had the hdhr plugged into 2 different unifi switches before. Always has worked perfectly. They used to be attached to a US-24-G1. But now are all connected to a USW-Pro-Max-24. DNS + DHCP runs from a RPi and an old MacBook running Debian Linux.
Its probably not any sort of hardware issue. Most likely, something is wrong with the way your setup is configured, but you haven't given enough info. You should post on the unifi community forum.
