HDHOMERUN Dual quit working in channels
Hi,
My hdhomerun dual (legacy) suddenly quit working in my channels server. The tuner is still working via the windows hdhomerun setup app as well as the android app. However, the channels server configuration shows this in the sources page:
HDHomeRun DUAL
[0 channels] on [192.168.1.23]
No channels detected on this HDHomeRun. Please scan for channels, then [click here]to continue.
If no channels are found, you may need a better antenna.
It was working just a couple of days ago.
Thanks
My bad. I updated surfshark and it apparently broke local lan access with the vpn enabled.
