Hey guys,
Is there anything we might have to be worried about with these changes?
I would guess that unless you are specifically using IPv6 probably nothing to worry about.
HDHomeRun Firmware 20221010beta1
- Upgraded discover support.
- Add favorites to /lineup.m3u playlist.
- Fix parsing of URLs that do not have anything after the IP address.
- HDHR5/FLEX/SCRIBE/SERVIO: IPv6 support.
- HDHR5/FLEX/SCRIBE/SERVIO: Improvements to automatic reboot handling required for EU certification.
- FLEX/SCRIBE: Optimized handling of a new DVR request for the same channel from the same client.
- FLEX: Use the first 17.6TB of the hard drive rather than failing to configure a hard drive 18TB or larger.
- SCRIBE: Operate as a tuner only if the hard drive is removed or not functioning.
- EXTEND: Fix reporting of codec tag in http response when transcoding.
- Legacy: Update lineup URL.
- Legacy: Limit TTL for control requests (security).
