Just getting started with Channels, but no end of stuttering with a HDHomerun Flex 4K and I am a bit puzzled by this. Some channels work ok but most Channels complains about the connection - others work fine. I suspect it is signal related and the HDHomerun tech utility program shows some yellow vs green in signal quality
Interestingly I have an old Amazon Fire Recast box sitting right beside the HDHomerun, same type of antenna in the same place, and it gets nearly perfect signals when played live, but I am not sure if it is doing some magic in the box itself.
A bit puzzled and wondering if my HDHomerun needs swapping out.
