Hi
I have a 4 tuner HDHomerun Expand as source but for some reason some channels are missing EPG and some are missing channel logo or maybe has the wrong Channel logo.
Is it possible to setup another "Dummy" source with the correct EPG and Channel logos and map it with the channels from the HDHomerun.
So.. When tuning a channel, the picture source is from the HDHomerun but the EPG and Channels logos is from another source just mapped together.
Could this be done with a M3U source along with the HDHomerun source?
Thanks
Go to settings in the web ui > tap the gear next to the hdhr source > manage lineup > scroll to the channel with missing data > tap the pencil > assign the correct station from the list. You may need to delete and recreate the guide database after that. It’s under settings > guide database > gear > delete and recreate.
If that doesn’t work you can check to see if it’s missing from Gracenote by checking your area at zap2it. http://tvlistings.zap2it.com/
If they’re missing on zap2it you may have to do a m3u to fix them but that would be last resort.
Here is an example of a missing logo in channels guide data provider Gracenote.
It looks like the site is down. I have tried access during the weekend but without any luck
Seems to be working fine. Try googling zap2it and then entering your zip code or try this link.
I live in Europe. Could there be some kind of country restriction to this site.
