Hi I've tried googling this for awhile and can't find a fix.
I have two hdhomerun primes, both are static IPs on same subnet as each other and all Apple TV's. Launching the channels app says it's scanning and will find nothing, so I'll add the tuners by IP and it'll work fine for maybe 10 minutes before failing and showing there are no sources and having to reenter the IPs.
Is there a specific port that my router might be blocking that prevents the tuners from being scanned for?
Though if it would just remember the IPs I'd be happy even if they can't be scanned for.
