I finally got fed up with Comcast and stopped my cable service and bought an HDHomrrun Connect and an indoor HD antenna.
With the antenna connected straight to the TV I get excellent signal quality on all available over the air channels with my TV showing the lowest signal strength @ about 78%, most are in the 85-100% range.
However, as soon as I connect the antenna to the HDHomerun Connect and try and run it through the Channels app I can only get 1 or 2 channels to come in without issue. I have the Connect plugged directly into my wifi router but signal quality shown on the Connect tuner web page shows poor signal quality whether the Apple TV is connected via wifi or by Ethernet via a Powerline network adapter. Both of these connection types show that I’m getting near my maximum rated download speeds using the Speedtest app on the AppleTV.
I previously had 2 HDHomerun Primes running on my network without too many problems overall, but the Connect is not doing so well…
If I can’t get this to work may have to scrap Channels which would really suck because I love the app and the developer’s support is fantastic. Just don’t want to have to go back to Comcast if I can avoid it and would still like to use Channels for viewing and recording via the AppleTV.
Any suggestions?
