In the last week I've had two recordings fail to record on the same CBS channel.
It just gives a message:
"Failed: Could not start stream on channel=[3.1]: HDHomeRun: Tune Failed."
I've been using the Channels DVR software with this HDHR quad tuner for a long time without issues. What further troubleshooting methods I can use to figure out what caused this?
Just to add information. The first time it failed was set to record 3 shows in a row on the same channel. The first show failed and the second two recorded fine. The second time it failed, I had tuned to that channel about an hour before just to check for any potential reception problems and it came in just fine.
