HDHR Firmware with M3U export
HDHomeRun Firmware (20220831beta1)
  • Add /lineup.m3u for use with VLC and other apps that import m3u channel lists.
Launch VLC, "Open Network Stream", and enter: http://hdhomerun.local/lineup.m3u
To go back to the channel selection list press stop.
To channel surf use the track-forward/track-back buttons.
I suggested this feature and am happy to see they added it.
What value does this have over using the HDHomeRun source already in Channels?
None. It's for interfacing with other software.
For channels, you could save this m3u file and edit it and load as Custom Channels. The advantage would be if you wanted different sets of channels exposed to different DVRs, or to control the exact lineup for some reason.
It works pretty good tested in channels no problem sample below ..
#EXTM3U
#EXTINF:-1 channel-id="2.1" channel-number="2.1" tvg-name="KATU",2.1 KATU
http://10.0.0.111:5004/auto/v2.1
#EXTINF:-1 channel-id="2.2" channel-number="2.2" tvg-name="Charge!",2.2 Charge!
http://10.0.0.111:5004/auto/v2.2
#EXTINF:-1 channel-id="2.3" channel-number="2.3" tvg-name="Comet",2.3 Comet
