FOX TVE stream.
FOX from HDHR Prime.
Now when I first looked at the prime before capturing this image it was only showing
a rate of around 875Kbps. Which I found extremely strange and still find confusing that the Prime is running lower data then the TVE streams.
FOX is not the only channel I'm seeing this behavior on either.
