Even after a second beta this isn’t working and I’m back to using my Connect. It’s such a fundamental problem that it can’t possible have affected all the DVB units or the SD forums would be awash with refund requests!!
However SD sent me some instructions to get more info for them…
Effectively use the hdhomerun_config_gui app (which is within the package contents of the HDHR app on a Mac). This allows you to tune each tuner by number (0-3 on a Quatro) rather than get the first available - which I think is what the HDHR/Channels client asks for. It also lets you set the tuner to power saving mode by selecting channel 0. This is what I found and posted back to SD…
The problem affects tuner 0 and tuner 2. Tuners 1 and 3 work normally. I can tune any channel and get 100 signal strength and quality. I can switch them in and out of power saving mode.
On tuners 0 and 2 the first time the unit turns on they come out of power saving mode and tune correctly. If I switch channels without going back to power saving mode they tune correctly. However once I set them back to power saving mode (channel 0) they are never able to come out of it again to retune a channel. The signal strength does read 100% but the underlying barber pole is grey instead of green and the signal quality and symbol quality bars are 0%.
