HDHR Streaming to SONOS of UK DVB-T/T2 Radio Stations (& poss TV Sound)
Apologies if I’m in the wrong forum section, please move this post if necessary.
I am seriously considering buying a SiliconDust UK HD Home Run (HDHR) Quattro for DVB-T & T2 home TV watching and recording and running it with Channels.
I also have SONOS speakers and would like to be able to access the off-air DVB-T/T2 radio streams via the HDHR and wondered if that is possible using http etc. I do listen to radio station internet streams on SONOS e.g. BBC but they can sometimes be unreliable. Are you streaming successfully to SONOS from HD Home Run?
I successfully (most of the time) use these HTTP HLS streams for BBC radio stations and BBC TV sound on SONOS:
I have seen this:
and this:
I hope my question makes sense and I look forward to hearing from a member of the Channels user community.
Thank you,
SM
I have not tried this, but I suspect the SONOS will not be able to stream directly from the HDHR because the format it uses is not one commonly used for audio.
I have figured this out and I am now able to play my hdhomerun radio channels through home assistant onto my Google home devices :slight_smile:
Hi @Howesey2k, Would you mind sharing your solution please.
Thanks,
Steve
So basically I have music assistant installed on my home assistant which works with Google Home, Sonos and other devices. I then went to the Channels DVR web interface. Went to guide, streamed audio only from the radio station. Copied the URL into Music assistant as a new Radio Station. Hope this helps.
