HDMI for Channels
I believe the ADB Tuner (@turtletank) will be able to import DRM channels once the HDHomerun app has DRM support.
I think a few people have been testing this, but I haven't gotten around to it.
I don't think there is any other way around DRM.
Well tvs can accept the signal is there no way to HDMI out a TV. I assume it can be reversed engineered. If man can make it man can break it
Sorry for spamming the boards, but can you guys check out my post about chrome capture?
@bnhf
Maybe you can get me pointed in the right direction. This is first time I have used Portainer.
I installed portainer on my Synology 218+ (DSM 7.2.1-69057). I attempted to run thru Stacks but it would just time out. I used your compose file from docker hub and set my variables.
I then switched and added thru container page using the same environments and it’s says it’s running.
Jumped to my channels server and attempted to load and getting the error in the image.
I’m not sure if it is a permission issue or if I am installing correctly. I 'm not sure where these scripts are but I haven’t found them. Do I need to install some folders or files in File Station? I remember when I installed ESPN+ container.
Thanks in advance for any help.
Also, here is the last hour of the log, if that helps.
cp: can't stat '/tmp/scripts/firetv/dtvstream/bmitune.sh': No such file or directory
2023-09-27T18:13:05.236487105Z List of devices attached
2023-09-27T18:13:05.269254010Z No existing ./scripts/onn/youtubetv/prebmitune.sh found or UPDATE_SCRIPTS set to true
2023-09-27T18:13:05.270032147Z cp: can't stat '/tmp/scripts/firetv/dtvstream/prebmitune.sh': No such file or directory
2023-09-27T18:13:05.264937556Z failed to authenticate to 10.0.1.74:5555
2023-09-27T18:13:05.237104855Z
2023-09-27T18:13:05.296772573Z No existing hulu.m3u found or UPDATE_M3US set to true
2023-09-27T18:13:05.286928087Z cp: can't stat '/tmp/scripts/onn/youtubetv/reboot.sh': No such file or directory
2023-09-27T18:13:05.284661235Z cp: can't stat '/tmp/scripts/onn/youtubetv/keep_alive.sh': No such file or directory
2023-09-27T18:13:05.282255360Z cp: can't stat '/tmp/scripts/onn/youtubetv/isconnected.sh': No such file or directory
2023-09-27T18:13:05.281211094Z cp: can't stat '/tmp/scripts/firetv/dtvstream/stopbmitune.sh': No such file or directory
2023-09-27T18:13:05.280530387Z No existing ./scripts/onn/youtubetv/stopbmitune.sh found or UPDATE_SCRIPTS set to true
2023-09-27T18:13:05.278446256Z cp: can't stat '/tmp/scripts/firetv/dtvstream/bmitune.sh': No such file or directory
2023-09-27T18:13:05.277777249Z No existing ./scripts/onn/youtubetv/bmitune.sh found or UPDATE_SCRIPTS set to true
2023-09-27T18:13:05.283460566Z cp: can't stat '/tmp/scripts/firetv/dtvstream/isconnected.sh': No such file or directory
2023-09-27T18:13:05.285670252Z cp: can't stat '/tmp/scripts/firetv/dtvstream/keep_alive.sh': No such file or directory
2023-09-27T18:13:05.288161977Z cp: can't stat '/tmp/scripts/firetv/dtvstream/reboot.sh': No such file or directory
2023-09-27T18:13:05.295109158Z No existing foo-fighters.m3u found or UPDATE_M3US set to true
2023-09-27T18:13:05.293227235Z No existing directv.m3u found or UPDATE_M3US set to true
2023-09-27T18:13:05.392603619Z [ENV] ALERT_AUTH_SERVER
2023-09-27T18:13:05.298092630Z No existing youtubetv.m3u found or UPDATE_M3US set to true
2023-09-27T18:13:05.391573772Z [START] androidhdmi-for-channels is starting
2023-09-27T18:13:05.299734331Z No existing sling.m3u found or UPDATE_M3US set to true
2023-09-27T18:13:05.392170740Z [ENV] Not loading env
2023-09-27T18:13:05.392498840Z [ENV] IPADDRESS 10.0.1.194:7654
2023-09-27T18:13:05.392553917Z [ENV] ALERT_SMTP_SERVER
2023-09-27T18:13:05.392651610Z [ENV] ALERT_EMAIL_FROM
2023-09-27T18:13:05.392689687Z [ENV] ALERT_EMAIL_PASS
2023-09-27T18:13:05.392737347Z [ENV] ALERT_EMAIL_TO
2023-09-27T18:13:05.392775105Z [ENV] ALERT_WEBHOOK_URL
2023-09-27T18:13:05.392828042Z [ENV] ALLOW_DEBUG_VIDEO_PREVIEW
2023-09-27T18:13:05.392885541Z [ENV] Creating tuner 1
2023-09-27T18:13:05.392926944Z [ENV] ENCODER1_URL http://10.0.1.70/0.ts
2023-09-27T18:13:05.392988228Z [ENV] TUNER1_IP 10.0.1.74:5555
2023-09-27T18:13:05.393046210Z [ENV] CMD1
2023-09-27T18:13:05.393240222Z [ENV] PRE SCRIPT ./scripts/firetv/dtvstream/prebmitune.sh
2023-09-27T18:13:05.393197652Z [ENV] TEECMD1
2023-09-27T18:13:05.393292277Z [ENV] START SCRIPT ./scripts/firetv/dtvstream/bmitune.sh
2023-09-27T18:13:05.393332017Z [ENV] STOP SCRIPT ./scripts/firetv/dtvstream/stopbmitune.sh
2023-09-27T18:13:05.393382894Z [ENV] REBOOT SCRIPT ./scripts/firetv/dtvstream/reboot.sh
2023-09-27T18:13:05.393431541Z [GIN-debug] [WARNING] Running in "debug" mode. Switch to "release" mode in production.
2023-09-27T18:13:05.393540841Z - using code: gin.SetMode(gin.ReleaseMode)
2023-09-27T18:13:05.393494318Z - using env: export GIN_MODE=release
2023-09-27T18:13:05.393593683Z
2023-09-27T18:13:05.393700145Z [GIN-debug] HEAD /favicon.ico --> github.com/gin-gonic/gin.(*RouterGroup).StaticFile.func1 (2 handlers)
2023-09-27T18:13:05.399859031Z [GIN-debug] Loaded HTML Templates (11):
2023-09-27T18:13:05.393627580Z [GIN-debug] GET /favicon.ico --> github.com/gin-gonic/gin.(*RouterGroup).StaticFile.func1 (2 handlers)
2023-09-27T18:13:05.400133709Z - config.html
2023-09-27T18:13:05.400042215Z - status_and_logs.html
2023-09-27T18:13:05.400097979Z -
2023-09-27T18:13:05.400240004Z - index.html
2023-09-27T18:13:05.400174707Z - editm3u.html
2023-09-27T18:13:05.400277691Z - logs.html
2023-09-27T18:13:05.400315068Z - status.html
2023-09-27T18:13:05.401066303Z [GIN-debug] GET /status --> main.statusPageHandler (2 handlers)
2023-09-27T18:13:05.400461595Z - stream.html
2023-09-27T18:13:05.400388718Z - m3us.html
2023-09-27T18:13:05.400424574Z - routes.html
2023-09-27T18:13:05.400352086Z - edit.html
2023-09-27T18:13:05.400586764Z [GIN-debug] HEAD /static/*filepath --> github.com/gin-gonic/gin.(*RouterGroup).createStaticHandler.func1 (2 handlers)
2023-09-27T18:13:05.400758740Z [GIN-debug] GET /m3u/:channel --> main.run.func4 (2 handlers)
2023-09-27T18:13:05.400802146Z [GIN-debug] GET /env --> main.run.func5 (2 handlers)
2023-09-27T18:13:05.400983954Z [GIN-debug] GET /logs/json --> main.run.func9 (2 handlers)
2023-09-27T18:13:05.400926154Z [GIN-debug] GET /status/andlogs --> main.run.func8 (2 handlers)
2023-09-27T18:13:05.400675161Z [GIN-debug] GET /routes --> main.run.func2 (2 handlers)
2023-09-27T18:13:05.400716860Z [GIN-debug] GET /play/tuner:tuner/:channel --> main.run.func3 (2 handlers)
2023-09-27T18:13:05.400630566Z [GIN-debug] GET / --> main.run.func1 (2 handlers)
2023-09-27T18:13:05.400498421Z
2023-09-27T18:13:05.400539149Z [GIN-debug] GET /static/*filepath --> github.com/gin-gonic/gin.(*RouterGroup).createStaticHandler.func1 (2 handlers)
2023-09-27T18:13:05.400886051Z [GIN-debug] GET /logs --> main.run.func7 (2 handlers)
2023-09-27T18:13:05.400842013Z [GIN-debug] GET /logs/text --> main.run.func6 (2 handlers)
2023-09-27T18:13:05.401025823Z [GIN-debug] GET /video --> main.run.func10 (2 handlers)
2023-09-27T18:13:05.401148412Z [GIN-debug] GET /stream --> main.run.func11 (2 handlers)
2023-09-27T18:13:05.401107184Z [GIN-debug] GET /api/status --> main.apiStatusHandler (2 handlers)
2023-09-27T18:13:05.401677559Z [GIN-debug] Listening and serving HTTP on :7654
2023-09-27T18:13:05.401638960Z [START] androidhdmi-for-channels is ready
2023-09-27T18:13:05.401512551Z [GIN-debug] GET /editm3u/:file --> main.run.func19 (2 handlers)
2023-09-27T18:13:05.401333016Z [GIN-debug] GET /edit --> main.run.func15 (2 handlers)
2023-09-27T18:13:05.401286619Z [GIN-debug] GET /status/channelsactivity --> main.run.func14 (2 handlers)
2023-09-27T18:13:05.401241384Z [GIN-debug] GET /test/email --> main.run.func13 (2 handlers)
2023-09-27T18:13:05.401188575Z [GIN-debug] GET /test/webhook --> main.run.func12 (2 handlers)
2023-09-27T18:13:05.401382512Z [GIN-debug] POST /save --> main.run.func16 (2 handlers)
2023-09-27T18:13:05.401424576Z [GIN-debug] POST /m3usave/:file --> main.run.func17 (2 handlers)
2023-09-27T18:13:05.401471769Z [GIN-debug] GET /m3us --> main.run.func18 (2 handlers)
2023-09-27T18:13:05.401557963Z [GIN-debug] GET /config --> main.run.func20 (2 handlers)
2023-09-27T18:13:05.401598556Z [GIN-debug] POST /configsave --> main.run.func21 (2 handlers)
2023-09-27T18:13:06.799719610Z
2023-09-27T18:13:06.800563119Z > [email protected] start
2023-09-27T18:43:05.501466277Z [STATS] CPU usage: 2.3340915284211885%
2023-09-27T18:13:08.123851847Z http://127.0.0.1:8000 http://172.17.0.3:8000
2023-09-27T18:13:08.122877180Z http://bf4dce417379:8000 http://localhost:8000
2023-09-27T18:13:08.122699673Z Listening on:
2023-09-27T18:13:06.800846432Z
2023-09-27T18:13:06.800759954Z > node ./index.js
2023-09-27T18:43:05.502409235Z [STATS] Memory used percent: 12.573637926215575%
2023-09-27T18:43:05.502367855Z [STATS] Memory used: 728 MiB
2023-09-27T18:43:05.502327863Z [STATS] Total memory: 5787 MiB
2023-09-27T18:43:05.502290128Z [STATS] NumGC = 0
2023-09-27T18:43:05.502249136Z [STATS] Sys = 13 MiB
2023-09-27T18:43:05.502209885Z [STATS] TotalAlloc = 3 MiB
2023-09-27T18:43:05.502125964Z [STATS] Alloc = 3 MiB
You're going to want to get this project running using Portainer-Stacks. It'll be worth it -- and you'll be better off in the long run for future projects.
It appears from your logs and description that you likely have an issue with the volume you're trying to bind. Which is this section of the docker-compose:
    volumes:
      - /data/ah4c/scripts:/opt/scripts # pre/stop/bmitune.sh scripts will be stored in this bound host directory under streamer/app
      - /data/ah4c/m3u:/opt/m3u # m3u files will be stored here and hosted at http://<hostname or ip>:7654/m3u for use in Channels DVR - Custom Channels settings
      - /data/ah4c/adb:/root/.android # Persistent data directory for adb keys
The part to the left of the colon can be whatever you want it to be, and is where your persistent files will be stored on the Docker host (your Synology). The part to the right of the colon are the directories you're mapping to inside the container -- these are not to be changed.
Since you're likely not running Docker or Portainer as root, you'll need to be sure the directories you're mapping to are ones that your "user" can access. Choose a base directory that works for you on the host, for example I use /data/ah4c, and then scripts, m3u and adb will be created for me under that base.
EDIT: Follow the same basic structure though, specifying paths that have scripts, m3u and adb as the final sub-directories, and group them under a directory called ah4c. What you have as a parent directory to ah4c is whatever works for you.
We have Silicon Dust support now thanks to @Edwin_Perez donating a couple units.
See https://github.com/sullrich/ah4c/blob/761ca801996939116a62b9cdd334612be472f92c/m3u/silicondust.m3u#L4
I just noticed you're running a slightly outdated docker-compose that's pulling bnhf/ah4c:test, but you want to use bnhf/ah4c:test2. Anyway, the compose you want to use is here:
Still not having any luck (yet). Attached are screenshots of Volume created and deployment error (partial).
Used the docker compose that you tagged.
One thing I noticed is that no place to specify the volume in Stacks. I created the volume in Volume but haven’t been able attach to a container.
Gonna take a break & chill for tonight. I’m sure we’ll figure it out after some libations!
Portainer was installed with root.
The volumes get specified in your docker-compose. Make sure you grab the whole thing from the code block in the post I linked.
Still trying but no luck. I’ve attached a notification snippet and a screenshot of my folder architecture.
I get a lot of errors for tuners and encoders from 2-4 (that’s probably normal) but the bind mount failure is probably the issue.
I’m going to move the data folder to the portainer folder and see if it helps.
Network myah4c_default Creating Network myah4c_default Created Container ah4c Creating Container ah4c Created Container ah4c Starting Error response from daemon: Bind mount failed: '/data/ah4c/scripts' does not exists
So Close. You need to add volume1 to the beginning of the path. So your path should be /volume1/data/ah4c/scripts
BINGO!!!!
I added the volume1 in the compose file from @bnhf and it fires up. I checked in filestation and the files and folders are there. I figured it was something simple. This is the first time I have used Portainer; all my other containers were initialized using the docker wizard on the Synology NAS which makes you select the folder.
Hopefully, later today I’ll have time to make sure everything is working as expected.
Step1: Install Portainer on Synology NAS. :heavy_check_mark:
Step 2: Install ah4c in Portainer. :heavy_check_mark:
Step 3: Install as source in Channels and confirm working status.
Step 4: Install Pluto & ESPN+ containers into Portainer.
Step 5: Test all custom channels thru my server on the test NAS.
Step 6: Migrate portainer to primary NAS.
Thanks to @bnhf & @cyoungers for getting me this far.
For those non-techie's like me, I used the excellent tutorial from mariushosting to install portainer on my Synology NAS.
@turtletank, do you know if the screenshot, showing 60 fps for both h265 and h264 on Chromecast, was the 4K device, or the HD version. My HD version shows h265/60fps, and h264/30fps. The link to the Hulu page just says "Chromecast" under the 1080p list, and does not specify between the latest versions. Thanks.
FYI, good info on many of these types of video encoders. Near end can see common passwords for Telnet into these boxes (I was able to get into mine using this info):
Also good reminder to keep such a device away for the public / WAN !
Yeah, never expose those devices to WAN, and always watch them on LAN. My J-Tech branded device does not seem to be too phishy, but I'll keep watching it. I know some of the Uray use an Ambarella SoC instead of HiSilicon, but not sure if they are any more or less secure.
If you want better updates and visibility, may be worth looking into LinkPi encoders. There is a great write up here.
Link Pi ENC1 / TBS 2603SE encoders
Wow, I would love to try this out, but not sure where to begin. I'm not a programmer. I have some reading to do to see how to get this to work with ADB and Spectrum. Currently, I'm running CC4C with Spectrum pretty successfully.
Can someone compile the apk?
@doug8796:
I can build debug apks, obviously. I'd have to look into building a release apk and hosting it on github. I'm not able to test right now, though, so would need a volunteer to do that for me. First, let me check with the upstream author to see if he's willing to accpet my pull request. The last time I checked a few weeks ago, he was on vacation and not able to do anything even if he wanted to.
I would test. Let me know. I'll have to get a Walmart Onn device and an HDMI encoder.
@arwrite
I heard from the upstream author. He's still unavailable so I will build a release version myself but it might take me a few days. Please pm me your email address and I'll send it to you when it's ready.
