I'm trying to consolidate multiple DVR servers.
There are many reasons I run multiple servers and not going to get into that here as it would just muddy the water.
One reason is I want to record certain shows from Xfinity TVE since the channels thay air on are in HD vs. SD on my HDHR Prime source. Currently, I record them using passes via TVE on one server and duplicate passes via HDHR Prime using another server. That way, if the TVE recording isn't interrupted (it happens), I keep it and delete the HDHR Prime SD recording. If is was interrupted, I delete it and keep the SD recording from the Prime until I can record it in HD again.
I'm also experiencing a problem where my HDHR Prime does background channel scans every ~3 days and if my Xfinity cable happens to be down when it background scans (we never know when it will scan), the HDHR says I have 0 channels subscribed so all recordings will fail for ~3 days until the next background channel scan sees them again.
So in order to work around that problem, I created a custom m3u source that points to my HDHR Prime.
Server1 sources - (#1) HDHR Prime, (#2) Xfinity TVE
Server2 sources - (#1) m3u for same HDHR Prime used by Server1
I could easily put all three sources on the same server, but the problem is I cannot create a pass to record the same show at the same time on both TVE and HDHR sources. I know I could manually select each show to record, but that's too much work and the air times could change. It's working as it is, but I would like to get back to using a single DVR server.
Any ideas?
