I have three individual channels all setup and working
- ION
- DEFY
- AXS TV NOW
But I have NO IDEA how to setup up the EPG
all are east coast
can anyone help me figure this out???
thanks in advance
all are east coast
thanks in advance
Are these channels from a "Custom Channe?" (*.m3u) or are these from TVE (Cable,philo, etc?")
If its from a TVE source, It should automaticly work.
But from the Web UI. Click The grear icon next to the source and click "Manage lineup" It will open a page then you can navigate to the individual channel and try to map the channel that way.
If its from a M3U its going to depend if they have EPG for those 3 channels. If they dont you can add the source with no EPG and try to map it using GraceNotes.
they are single channels via M3U files! How would I map them using Gracenotes??
Chrome -> Web UI (settings page) -> Scroll down to Sources -> Click the gear icon next to sources -> Clickn Manage Lineup and new window appears -> Click pencil (edit icon) -> Search for channel by name and by callsign
ION TV and DEFY worked perfectly!
AXS TV Now was a different story!
I still have no clue as to this one!
It would be great if someone knew the Station code for "AXS TV NOW!"
It should be "AXSTNST" or 123156.
Nope! That's AXS TV
I need "AXS TV NOW"
But, thank you for trying!
Did you try it? It says "AXS TV Now" and has different shows than AXS TV.
Another option is to use the XMLTV file here.
just found out! it's the right channel! just the wrong time zone!
the show I'm watching now shows in the guide 4 hours later!
OMG I'm so close to get this to work!
thank you so much for trying! I'm thankful for people like you!
I wish I could just find an M3U and epg.xml link for "AXS TV" instead of AXS TV NOW!
M3U4U.com is a great tool that offers EPG time shifting, might be of help in this context?
Manager | Wiki - m3u4u
That is the type of feature I was looking for, but I'm not sure if/how it could be used with the Gracenote data (and not a separate XMLTV feed).
