Help installing Auto wake helper on MacBook Pro
Main computer just died so I need something to use to record my channels in the mean time, I installed it on my MacBook Pro and it's asking to install the " Auto wake helper" but I keep getting this error in my logs when I do.
"0:145: execution error: The administrator user name or password was incorrect. (-60007)
2022/01/24 03:22:36.763817 [ERR] Failed to install wake helper: exit status 1
2022/01/24 03:36:14.148031 [ERR] Failed to install wake helper: exit status 1"
help? Thanks
I mean it says the admin user name and password wasn't correct. I would say that's the issue. Are you sure you are using the correct user name and password.
Open Terminal.app and paste this:
sudo ~/Library/Application\ Support/ChannelsDVR/install.sh --wake-helper
