Help me understand
First off, I loaded the image on my RPi4 on the SD card and its so far working amazing. By far the easiest set up I have used. Love it.
Second, running my raspi, it decodes it I understand, so am I limited to streams or how many channels I can record or even watch while recording at the same time? I was recording and watching at the same time without problem, so jw what my limits were.
TIA
Nothing is being decoded.
The limit is based on your available bandwidth and disk speed. SD card will not be as fast as a USB disk, and will become corrupted after heavy use.
so i should switch out my program to a USB? Can you advise which is the best USB to use and also a link for help in support
