Having trouble setting up Mac mini. Was running Channels DVR on MacBook Pro with all media saved to share on 4TB MyCloud NAS as a test. Uninstalled from MacBook Pro and installed on 2011 Mac Mini (4GB, 500GB) DVR pointing again to the share on 4TB MyCloud NAS. It set up fine but only the settings tab is now showing. None of the guide, recordings, DVR history was recognized. It sees the NAS reporting data size remaining and also recognizes the HDHomeRun Prime with cable card. What do I need to do so it gets my history from the NAS share?
You need to restore the settings onto the new installation, by unchecking the DVR box and then going to http://127.0.0.1:8089/restore
Thanks for the quick reply. All is well now.
I typed to soon. I am unable to play recorded show from the AppleTV or the Web UI. If I press play for the recording in the AppleTV it immediately quits back to the listing page. In the Web UI it shows transcoded finished after 1 sec but when play is pressed nothing happens.
What does the Log say?
Sounds like either the DVR path is incorrect, or the permissions on the old files/directories aren’t letting the DVR access them.
Here’s the logs since setup:
2017/03/21 15:32:17 [SYS] Starting Channels DVR v2017.03.21.0415 (darwin-x86_64) in /Users/richard/channels-dvr/data
2017/03/21 15:32:19 [HDR] Found 1 devices
2017/03/21 15:32:27 [SYS] Started HTTP Server
2017/03/21 15:32:54 [DVR] Recording engine started in /Volumes/ChannelsDVR
2017/03/21 15:32:54 [SYS] Bonjour service running for dvr-mac-mini-mc.local. [10.0.1.16]
2017/03/21 15:32:54 [NAT] Successfully mapped port 8089 using natpmp
2017/03/21 15:32:54 [ERR] Could not create backup: mkdir /Volumes/ChannelsDVR: permission denied
2017/03/21 15:33:07 [IDX] Pruned 50 expired airings from USA-CA56663-DEFAULT in 3.127493038s.
2017/03/21 16:28:39 [SYS] Starting Channels DVR v2017.03.21.0415 (darwin-x86_64) in /Users/richard/channels-dvr/data
2017/03/21 16:28:41 [HDR] Found 1 devices
2017/03/21 16:28:41 [SYS] Started HTTP Server
2017/03/21 16:28:48 [DVR] Recording engine started in /Volumes/ChannelsDVR
2017/03/21 16:28:48 [SYS] Bonjour service running for dvr-mac-mini-mc.local. [10.0.1.16]
2017/03/21 16:28:48 [NAT] Successfully mapped port 8089 using natpmp
2017/03/21 16:28:48 [ERR] Could not create backup: mkdir /Volumes/ChannelsDVR: permission denied
2017/03/21 16:28:58 [IDX] Pruned 33 expired airings from USA-CA56663-DEFAULT in 717.932526ms.
2017/03/21 16:35:52 [SYS] Starting Channels DVR v2017.03.21.0415 (darwin-x86_64) in /Users/richard/channels-dvr/data
2017/03/21 16:35:53 [HDR] Found 1 devices
2017/03/21 16:35:53 [SYS] Started HTTP Server
2017/03/21 16:36:02 [DVR] Recording engine started in /Volumes/ChannelsDVR
2017/03/21 16:36:02 [SYS] Bonjour service running for dvr-mac-mini-mc.local. [10.0.1.16]
2017/03/21 16:36:02 [NAT] Successfully mapped port 8089 using natpmp
2017/03/21 16:36:02 [ERR] Could not create backup: mkdir /Volumes/ChannelsDVR: permission denied
2017/03/21 16:36:14 [IDX] Pruned 13 expired airings from USA-CA56663-DEFAULT in 1.253106648s.
2017/03/21 16:45:00 [HLS] Starting transcoder for file-94 at 1m18s (encoder=h264_videotoolbox, resolution=, deinterlacer=blend, bitrate=10000)
/Volumes/ChannelsDVR/TV/Modern Family/2017-02-15-2059 Modern Family 2017-02-15 S08E13 Do It Yourself.mpg: No such file or directory
2017/03/21 16:45:00 [HLS] Stopping transcoder for file-94 after seek to 1m18s (out=0s, finished=true)
2017/03/21 16:45:02 [HLS] Stopping transcoder for file-94 after seek to 1m18s (out=0s, finished=true)
2017/03/21 16:45:02 [HLS] Starting transcoder for file-94 at 1m18s (encoder=h264_videotoolbox, resolution=, deinterlacer=blend, bitrate=10000)
2017/03/21 16:45:06 [HLS] Stopping transcoder for file-94 after seek to 1m18s (out=0s, finished=true)
2017/03/21 16:45:06 [HLS] Starting transcoder for file-94 at 1m18s (encoder=h264_videotoolbox, resolution=, deinterlacer=blend, bitrate=10000)
2017/03/21 16:45:10 [HLS] Stopping transcoder for file-94 after seek to 1m18s (out=0s, finished=true)
2017/03/21 16:45:10 [HLS] Starting transcoder for file-94 at 1m18s (encoder=h264_videotoolbox, resolution=, deinterlacer=blend, bitrate=10000)
2017/03/21 16:45:14 [HLS] Stopping transcoder session file-94 @ 0s
2017/03/21 16:47:43 [HLS] Starting transcoder for file-89 at 2m22s (encoder=h264_videotoolbox, resolution=, deinterlacer=blend, bitrate=10000)
2017/03/21 16:47:44 [HLS] Stopping transcoder for file-89 after seek to 2m22s (out=0s, finished=false)
2017/03/21 16:47:44 [HLS] Starting transcoder for file-89 at 2m22s (encoder=h264_videotoolbox, resolution=, deinterlacer=blend, bitrate=10000)
/Volumes/ChannelsDVR/TV/Superior Donuts/2017-02-13-2059 Superior Donuts 2017-02-13 S01E03 Crime Time.mpg: No such file or directory
2017/03/21 16:47:46 [HLS] Stopping transcoder for file-89 after seek to 2m22s (out=0s, finished=true)
2017/03/21 16:47:46 [HLS] Starting transcoder for file-89 at 2m22s (encoder=h264_videotoolbox, resolution=, deinterlacer=blend, bitrate=10000)
2017/03/21 16:47:50 [HLS] Stopping transcoder for file-89 after seek to 2m22s (out=0s, finished=true)
2017/03/21 16:47:50 [HLS] Starting transcoder for file-89 at 2m22s (encoder=h264_videotoolbox, resolution=, deinterlacer=blend, bitrate=10000)
2017/03/21 16:47:54 [HLS] Stopping transcoder for file-89 after seek to 2m22s (out=0s, finished=true)
2017/03/21 16:47:54 [HLS] Starting transcoder for file-89 at 2m22s (encoder=h264_videotoolbox, resolution=, deinterlacer=blend, bitrate=10000)
2017/03/21 16:48:00 [HLS] Stopping transcoder for file-89 after seek to 2m22s (out=0s, finished=true)
2017/03/21 16:48:00 [HLS] Starting transcoder for file-89 at 2m22s (encoder=h264_videotoolbox, resolution=, deinterlacer=blend, bitrate=10000)
2017/03/21 16:48:06 [HLS] Stopping transcoder for file-89 after seek to 2m22s (out=0s, finished=true)
2017/03/21 16:48:06 [HLS] Starting transcoder for file-89 at 2m22s (encoder=h264_videotoolbox, resolution=, deinterlacer=blend, bitrate=10000)
2017/03/21 16:48:11 [HLS] Stopping transcoder for file-89 after seek to 2m22s (out=0s, finished=true)
2017/03/21 16:48:23 [HLS] Starting transcoder for file-89 at 2m22s (encoder=h264_videotoolbox, resolution=, deinterlacer=blend, bitrate=10000)
2017/03/21 16:48:23 [HLS] Stopping transcoder for file-89 after seek to 2m22s (out=0s, finished=true)
2017/03/21 16:48:25 [HLS] Stopping transcoder for file-89 after seek to 2m22s (out=0s, finished=true)
2017/03/21 16:48:25 [HLS] Starting transcoder for file-89 at 2m22s (encoder=h264_videotoolbox, resolution=, deinterlacer=blend, bitrate=10000)
2017/03/21 16:48:26 [HLS] Stopping transcoder for file-89 after seek to 2m22s (out=0s, finished=true)
2017/03/21 16:48:26 [HLS] Starting transcoder for file-89 at 2m22s (encoder=h264_videotoolbox, resolution=, deinterlacer=blend, bitrate=10000)
2017/03/21 16:48:29 [HLS] Stopping transcoder for file-89 after seek to 2m22s (out=0s, finished=true)
2017/03/21 16:48:36 [HLS] Starting transcoder for file-89 at 2m22s (encoder=h264_videotoolbox, resolution=, deinterlacer=blend, bitrate=10000)
2017/03/21 16:48:38 [HLS] Stopping transcoder for file-89 after seek to 2m22s (out=0s, finished=true)
2017/03/21 16:48:38 [HLS] Starting transcoder for file-89 at 2m22s (encoder=h264_videotoolbox, resolution=, deinterlacer=blend, bitrate=10000)
2017/03/21 16:48:43 [HLS] Stopping transcoder for file-89 after seek to 2m22s (out=0s, finished=true)
2017/03/21 16:48:43 [HLS] Starting transcoder for file-89 at 2m22s (encoder=h264_videotoolbox, resolution=, deinterlacer=blend, bitrate=10000)
2017/03/21 16:48:49 [HLS] Stopping transcoder for file-89 after seek to 2m22s (out=0s, finished=true)
2017/03/21 16:48:50 [HLS] Starting transcoder for file-89 at 2m22s (encoder=h264_videotoolbox, resolution=, deinterlacer=blend, bitrate=10000)
2017/03/21 16:48:51 [HLS] Stopping transcoder for file-89 after seek to 2m22s (out=0s, finished=false)
2017/03/21 16:48:51 [HLS] Starting transcoder for file-89 at 2m22s (encoder=h264_videotoolbox, resolution=, deinterlacer=blend, bitrate=10000)
2017/03/21 16:48:57 [HLS] Stopping transcoder for file-89 after seek to 2m22s (out=0s, finished=true)
2017/03/21 16:48:57 [HLS] Starting transcoder for file-89 at 2m22s (encoder=h264_videotoolbox, resolution=, deinterlacer=blend, bitrate=10000)
2017/03/21 16:49:00 [HLS] Stopping transcoder for file-89 after seek to 2m22s (out=0s, finished=true)
2017/03/21 16:49:00 [HLS] Starting transcoder for file-89 at 2m22s (encoder=h264_videotoolbox, resolution=, deinterlacer=blend, bitrate=10000)
2017/03/21 16:49:01 [HLS] Stopping transcoder session file-89 @ 0s
2017/03/21 16:49:06 [HLS] Starting transcoder for file-97 at 0s (encoder=h264_videotoolbox, resolution=, deinterlacer=blend, bitrate=10000)
/Volumes/ChannelsDVR/TV/Life in Pieces/2017-02-16-2129 Life in Pieces 2017-02-16 S02E14 Facebook Fish Planner Backstage.mpg: No such file or directory
2017/03/21 16:49:18 [HLS] Stopping transcoder session file-97 @ 0s
2017/03/21 16:49:45 [SYS] Shutting down...
2017/03/21 16:49:45 [DVR] Recording engine stopped.
2017/03/21 16:49:45 [SYS] Starting Channels DVR v2017.03.21.0415 (darwin-x86_64) in /Users/richard/channels-dvr/data
2017/03/21 16:49:46 [HDR] Found 1 devices
2017/03/21 16:49:47 [SYS] Started HTTP Server
2017/03/21 16:49:49 [DVR] Recording engine started in /Volumes/ChannelsDVR
2017/03/21 16:49:49 [SYS] Bonjour service running for dvr-mac-mini-mc.local. [10.0.1.16]
2017/03/21 16:49:49 [ERR] Could not create backup: mkdir /Volumes/ChannelsDVR: permission denied
2017/03/21 16:49:49 [NAT] Successfully mapped port 8089 using natpmp
2017/03/21 16:50:00 [IDX] Pruned 1 expired airings from USA-CA56663-DEFAULT in 743.469462ms.
2017/03/21 16:50:41 [HLS] Starting transcoder for file-89 at 2m22s (encoder=h264_videotoolbox, resolution=, deinterlacer=blend, bitrate=10000)
2017/03/21 16:50:42 [HLS] Stopping transcoder for file-89 after seek to 2m22s (out=0s, finished=true)
2017/03/21 16:50:42 [HLS] Starting transcoder for file-89 at 2m22s (encoder=h264_videotoolbox, resolution=, deinterlacer=blend, bitrate=10000)
2017/03/21 16:50:45 [HLS] Stopping transcoder for file-89 after seek to 2m22s (out=0s, finished=true)
2017/03/21 16:50:45 [HLS] Starting transcoder for file-89 at 2m22s (encoder=h264_videotoolbox, resolution=, deinterlacer=blend, bitrate=10000)
2017/03/21 16:50:49 [HLS] Stopping transcoder for file-89 after seek to 2m22s (out=0s, finished=true)
2017/03/21 16:50:49 [HLS] Starting transcoder for file-89 at 2m22s (encoder=h264_videotoolbox, resolution=, deinterlacer=blend, bitrate=10000)
2017/03/21 16:50:52 [HLS] Stopping transcoder for file-89 after seek to 14s (out=0s, finished=true)
2017/03/21 16:50:52 [HLS] Starting transcoder for file-89 at 14s (encoder=h264_videotoolbox, resolution=, deinterlacer=blend, bitrate=10000)
2017/03/21 16:50:53 [HLS] Stopping transcoder for file-89 after seek to 14s (out=0s, finished=true)
2017/03/21 16:50:53 [HLS] Starting transcoder for file-89 at 14s (encoder=h264_videotoolbox, resolution=, deinterlacer=blend, bitrate=10000)
2017/03/21 16:50:56 [HLS] Stopping transcoder for file-89 after seek to 14s (out=0s, finished=true)
2017/03/21 16:50:56 [HLS] Starting transcoder for file-89 at 14s (encoder=h264_videotoolbox, resolution=, deinterlacer=blend, bitrate=10000)
2017/03/21 16:50:59 [HLS] Stopping transcoder for file-89 after seek to 14s (out=0s, finished=true)
2017/03/21 16:50:59 [HLS] Starting transcoder for file-89 at 14s (encoder=h264_videotoolbox, resolution=, deinterlacer=blend, bitrate=10000)
2017/03/21 16:51:04 [HLS] Stopping transcoder for file-89 after seek to 14s (out=0s, finished=true)
2017/03/21 16:51:04 [HLS] Starting transcoder for file-89 at 14s (encoder=h264_videotoolbox, resolution=, deinterlacer=blend, bitrate=10000)
2017/03/21 16:51:09 [HLS] Stopping transcoder for file-89 after seek to 14s (out=0s, finished=true)
2017/03/21 16:51:09 [HLS] Starting transcoder for file-89 at 14s (encoder=h264_videotoolbox, resolution=, deinterlacer=blend, bitrate=10000)
2017/03/21 16:51:11 [HLS] Stopping transcoder session file-89 @ 0s
2017/03/21 16:52:55 [HLS] Starting transcoder for file-89 at 9m42s (encoder=h264_videotoolbox, resolution=, deinterlacer=blend, bitrate=10000)
2017/03/21 16:52:56 [HLS] Stopping transcoder for file-89 after seek to 9m42s (out=0s, finished=true)
2017/03/21 16:52:56 [HLS] Starting transcoder for file-89 at 9m42s (encoder=h264_videotoolbox, resolution=, deinterlacer=blend, bitrate=10000)
2017/03/21 16:52:59 [HLS] Stopping transcoder for file-89 after seek to 9m42s (out=0s, finished=true)
2017/03/21 16:52:59 [HLS] Starting transcoder for file-89 at 9m42s (encoder=h264_videotoolbox, resolution=, deinterlacer=blend, bitrate=10000)
2017/03/21 16:53:03 [HLS] Stopping transcoder for file-89 after seek to 9m42s (out=0s, finished=true)
2017/03/21 16:53:03 [HLS] Starting transcoder for file-89 at 9m42s (encoder=h264_videotoolbox, resolution=, deinterlacer=blend, bitrate=10000)
2017/03/21 16:53:37 [HLS] Stopping transcoder for file-89 after seek to 0s (out=0s, finished=true)
2017/03/21 16:53:37 [HLS] Starting transcoder for file-89 at 0s (encoder=h264_videotoolbox, resolution=, deinterlacer=blend, bitrate=10000)
2017/03/21 16:53:44 [HLS] Stopping transcoder session file-89 @ 0s
2017/03/21 16:53:49 [HLS] Starting transcoder for file-85 at 5m24s (encoder=h264_videotoolbox, resolution=, deinterlacer=blend, bitrate=10000)
/Volumes/ChannelsDVR/TV/Saturday Night Live/2017-02-11-2159 Saturday Night Live 2017-02-11 From Feb 23 1991 Alec Baldwin Whitney Houston.mpg: No such file or directory
2017/03/21 16:53:51 [HLS] Stopping transcoder for file-85 after seek to 5m24s (out=0s, finished=true)
2017/03/21 16:53:51 [HLS] Starting transcoder for file-85 at 5m24s (encoder=h264_videotoolbox, resolution=, deinterlacer=blend, bitrate=10000)
2017/03/21 16:53:54 [HLS] Stopping transcoder for file-85 after seek to 5m24s (out=0s, finished=true)
2017/03/21 16:53:54 [HLS] Starting transcoder for file-85 at 5m24s (encoder=h264_videotoolbox, resolution=, deinterlacer=blend, bitrate=10000)
2017/03/21 16:53:57 [HLS] Stopping transcoder for file-85 after seek to 5m24s (out=0s, finished=true)
2017/03/21 16:53:57 [HLS] Starting transcoder for file-85 at 5m24s (encoder=h264_videotoolbox, resolution=, deinterlacer=blend, bitrate=10000)
2017/03/21 16:53:59 [HLS] Stopping transcoder session file-85 @ 0s
2017/03/21 16:54:08 [HLS] Starting transcoder for file-103 at 0s (encoder=h264_videotoolbox, resolution=, deinterlacer=blend, bitrate=10000)
/Volumes/ChannelsDVR/TV/Saturday Night Live/2017-02-18-2159 Saturday Night Live 2017-02-18 Melissa McCarthy Pheonix.mpg: No such file or directory
2017/03/21 17:04:47 [HLS] Stopping inactive session file-103 @ 0s
2017/03/21 17:12:14 [DVR] Rule 'CBS 2 News at 6:00' found 12 new airings
2017/03/21 17:12:14 [DVR] queued recording job 1490144340-14
2017/03/21 17:12:14 [DVR] queued recording job 1490230740-14
2017/03/21 17:12:14 [DVR] queued recording job 1490662740-14
2017/03/21 17:12:14 [DVR] queued recording job 1490749140-14
2017/03/21 17:12:14 [DVR] queued recording job 1490835540-14
2017/03/21 17:12:14 [DVR] queued recording job 1490921940-14
2017/03/21 17:12:14 [DVR] queued recording job 1491008340-14
2017/03/21 17:12:14 [DVR] queued recording job 1491353940-14
2017/03/21 17:12:14 [DVR] queued recording job 1491440340-14
2017/03/21 17:12:14 [DVR] queued recording job 1491526740-14
2017/03/21 17:12:14 [DVR] queued recording job 1491613140-14
2017/03/21 17:12:14 [DVR] queued recording job 1491872340-14
2017/03/21 17:12:14 [DVR] Waiting 46m45.821858723s until next job 1490144340-14
2017/03/21 17:12:27 [DVR] Rule 'CBS Evening News With Scott Pelley' found 14 new airings
2017/03/21 17:12:27 [DVR] queued recording job 1490146140-15
2017/03/21 17:12:27 [DVR] queued recording job 1490232540-15
2017/03/21 17:12:27 [DVR] queued recording job 1490308140-15
2017/03/21 17:12:27 [DVR] queued recording job 1490394540-15
2017/03/21 17:12:27 [DVR] queued recording job 1490664540-15
2017/03/21 17:12:27 [DVR] queued recording job 1490750940-15
2017/03/21 17:12:27 [DVR] queued recording job 1490837340-15
2017/03/21 17:12:27 [DVR] queued recording job 1490923740-15
2017/03/21 17:12:27 [DVR] queued recording job 1491010140-15
2017/03/21 17:12:27 [DVR] queued recording job 1491355740-15
2017/03/21 17:12:27 [DVR] queued recording job 1491442140-15
2017/03/21 17:12:27 [DVR] queued recording job 1491528540-15
2017/03/21 17:12:27 [DVR] queued recording job 1491614940-15
2017/03/21 17:12:27 [DVR] queued recording job 1491874140-15
2017/03/21 17:12:27 [DVR] Waiting 46m32.661558695s until next job 1490144340-14
2017/03/21 17:27:49 [HLS] Starting transcoder for file-89 at 9m42s (encoder=h264_videotoolbox, resolution=, deinterlacer=blend, bitrate=10000)
2017/03/21 17:27:51 [HLS] Stopping transcoder for file-89 after seek to 9m42s (out=0s, finished=true)
2017/03/21 17:27:51 [HLS] Starting transcoder for file-89 at 9m42s (encoder=h264_videotoolbox, resolution=, deinterlacer=blend, bitrate=10000)
2017/03/21 17:27:54 [HLS] Stopping transcoder for file-89 after seek to 9m42s (out=0s, finished=true)
2017/03/21 17:27:54 [HLS] Starting transcoder for file-89 at 9m42s (encoder=h264_videotoolbox, resolution=, deinterlacer=blend, bitrate=10000)
2017/03/21 17:27:57 [HLS] Stopping transcoder for file-89 after seek to 9m42s (out=0s, finished=true)
2017/03/21 17:27:57 [HLS] Starting transcoder for file-89 at 9m42s (encoder=h264_videotoolbox, resolution=, deinterlacer=blend, bitrate=10000)
2017/03/21 17:28:01 [HLS] Stopping transcoder for file-89 after seek to 8s (out=0s, finished=true)
2017/03/21 17:28:01 [HLS] Starting transcoder for file-89 at 8s (encoder=h264_videotoolbox, resolution=, deinterlacer=blend, bitrate=10000)
2017/03/21 17:28:04 [HLS] Stopping transcoder for file-89 after seek to 8s (out=0s, finished=true)
2017/03/21 17:28:04 [HLS] Starting transcoder for file-89 at 8s (encoder=h264_videotoolbox, resolution=, deinterlacer=blend, bitrate=10000)
2017/03/21 17:28:06 [HLS] Stopping transcoder for file-89 after seek to 8s (out=0s, finished=true)
2017/03/21 17:28:06 [HLS] Starting transcoder for file-89 at 8s (encoder=h264_videotoolbox, resolution=, deinterlacer=blend, bitrate=10000)
2017/03/21 17:28:09 [HLS] Stopping transcoder for file-89 after seek to 8s (out=0s, finished=true)
2017/03/21 17:28:09 [HLS] Starting transcoder for file-89 at 8s (encoder=h264_videotoolbox, resolution=, deinterlacer=blend, bitrate=10000)
2017/03/21 17:28:10 [HLS] Stopping transcoder session file-89 @ 0s
2017/03/21 17:49:49 [NAT] Successfully mapped port 8089 using natpmp
2017/03/21 17:59:00 [DVR] Starting job 1490144340-14 CBS 2 News at 6:00 on ch=[2]
2017/03/21 17:59:00 [DVR] Waiting 29m59.920049745s until next job 1490146140-15
2017/03/21 17:59:00 [DVR] Error running job 1490144340-14: mkdir /Volumes/ChannelsDVR: permission denied
2017/03/21 17:59:30 [DVR] Starting job 1490144340-14 CBS 2 News at 6:00 on ch=[2]
2017/03/21 17:59:30 [DVR] Waiting 29m29.482390928s until next job 1490146140-15
2017/03/21 17:59:30 [DVR] Error running job 1490144340-14: mkdir /Volumes/ChannelsDVR: permission denied
2017/03/21 18:00:00 [DVR] Starting job 1490144340-14 CBS 2 News at 6:00 on ch=[2]
2017/03/21 18:00:00 [DVR] Waiting 28m59.421843315s until next job 1490146140-15
2017/03/21 18:00:00 [DVR] Error running job 1490144340-14: mkdir /Volumes/ChannelsDVR: permission denied
2017/03/21 18:00:30 [DVR] Starting job 1490144340-14 CBS 2 News at 6:00 on ch=[2]
2017/03/21 18:00:30 [DVR] Waiting 28m29.048661176s until next job 1490146140-15
2017/03/21 18:00:30 [DVR] Error running job 1490144340-14: mkdir /Volumes/ChannelsDVR: permission denied
2017/03/21 18:01:01 [DVR] Starting job 1490144340-14 CBS 2 News at 6:00 on ch=[2]
2017/03/21 18:01:01 [DVR] Waiting 27m58.928905221s until next job 1490146140-15
2017/03/21 18:01:01 [DVR] Error running job 1490144340-14: mkdir /Volumes/ChannelsDVR: permission denied
2017/03/21 18:01:31 [DVR] Starting job 1490144340-14 CBS 2 News at 6:00 on ch=[2]
2017/03/21 18:01:31 [DVR] Waiting 27m28.849475251s until next job 1490146140-15
2017/03/21 18:01:31 [DVR] Error running job 1490144340-14: mkdir /Volumes/ChannelsDVR: permission denied
2017/03/21 18:02:01 [DVR] Starting job 1490144340-14 CBS 2 News at 6:00 on ch=[2]
2017/03/21 18:02:01 [DVR] Waiting 26m58.697642095s until next job 1490146140-15
2017/03/21 18:02:01 [DVR] Error running job 1490144340-14: mkdir /Volumes/ChannelsDVR: permission denied
2017/03/21 18:02:31 [DVR] Starting job 1490144340-14 CBS 2 News at 6:00 on ch=[2]
2017/03/21 18:02:31 [DVR] Waiting 26m28.549715517s until next job 1490146140-15
2017/03/21 18:02:31 [DVR] Error running job 1490144340-14: mkdir /Volumes/ChannelsDVR: permission denied
2017/03/21 18:03:01 [DVR] Skipping job because program already started 1490144340-14 CBS 2 News at 6:00
2017/03/21 18:03:01 [DVR] Waiting 25m58.473631154s until next job 1490146140-15
Looks like permissions are wrong, and perhaps the directory is wrong as well? You will need to figure out how to fix the “permission denied” and “no such file or directory” errors.
Find that volume in finder and right click “Get Info” to check the permissions set on it.
Strange. I choose it via the Web UI on the Mac mini. I’ll look at it and try to figure it out. Thanks.
