Help Needed Changing NVIDIA Shield Hard Drive
Help needed to replace Hard Drive on NVIDIA Shield using Channels DVR.
What is the recommended procedure when using TVE Channels as well as OTA Channels DVR. Shield is 2018 model. All SFW is auto updated.
Don't need to save TV recordings, but like to save season pass data, FAVs, etc. data so as not to have a need for system rebuild.
Thanks in advance for your help. New experience for me.
Open the dvr web UI using your shield's IP. You can uncheck the dvr checkbox and edit the drive to use below.
Thanks for the fast reply. Will replace the HDD next week.
Successfully replaced HDD. Disc check showed file error on several TV files. Returning old HDD under warranty.
Replacement fixed problems of playback stuttering and hangup, FF and REW NOGO, commercial skip failures.
