I have the LOTR Extended Edition in my imported library and they play just fine. However, each of the three movies in the trilogy have two parts. I am either too lazy or too cheap to do a proper join of each to a single file and this creates a few of issues in how it is presented in the UI:
- The description of the file on the ATV removes the "Part 1, Part 2" bits
- The poster does not differentiate by parts (understandable)
- The order is in reverse for some reason (i.e. Part 2 is presented before Part 1)
Any suggestions on how I might fix one or more of these? Or should i just figure out how to do a proper joint of the two parts?
Also, ideally, the trilogy itself would be presented in the proper order. I suppose the lack of numbering in the title prevent this. But In the UI I get Fellowship of the Ring, Return of the King, and then The Two Towers.
I am running 2020.09.14.2346
Any suggestions would be appreciated. TIA
