Help with Linux
I am a newbie to Linux Mint and currently running Channels DVR thru my browser (http://localhost:8089). How do I automount it to run from the command line? I'm sorry I don't yet know the proper lingo.
It should start automatically at boot if you used the official install instructions.
Are you trying to mount a disk, or do something else?
I used the instructions from the website. Everything worked well until i closed that window. What i previously meant was how do i have it start up on boot up of the laptop it's installed on.
It should start and be always running on a reboot. Did you install on the internal drive or a usb plug in storage. Did you install in your /home directory?
