I'm sure I'm doing something wrong, maybe someone can help explain? I am learning how to use Smart Rules with the various criteria, in the regular editor as well as the advanced one. So much possibility here, it's super cool stuff!
However when I try to use the "Season Number" or "Episode Number" criteria (which are listed as supported on the Support page) I'm not getting any results. What is the proper syntax, if I wanted to find all of the episodes that are marked S01E01 in my recording and TV library? Or is there a different way for searching for just "pilots?" Which would be the easier, more reliable method? Ultimately I'm trying to create a Collection and Virtual Channel of "classic TV pilots" ... and this seems to be the only way to limit it to those episodes only, and not subsequent ones from each and every show.
