Error 403 forbidden: accesa to resource path denied. Been this way for over 1 hr now.
TLC is working fine for me, but HGTV is not wokring.
2020/04/03 19:27:25.064983 [TVE] action=navigate url=https://login.discovery.com/v1/oauth2/authorize?affiliate_id=57a9eb716b66d14b2ff8aedb&asset_authz=true&auth_client_id=Comcast_SSO&auth_client_url=&auth_ttl=1209600&client_id=3020a40c2356a645b4b4&network_requestors=true&product.code=hgtv&redirect_uri=https%3A%2F%2Fwatch.hgtv.com%2Fwatch%2Fhgtv&response_flow=code&response_type=adobe&state=nonce%2Co9u9QD0NzhPLtsVQ7OcCW3rNgNKZe5r8
2020/04/03 19:27:25.065563 [TVE] action=request type=Document method=GET url=https://login.discovery.com/v1/oauth2/authorize
2020/04/03 19:27:25.375631 [TVE] action=request type=Document method=GET url=https://api.auth.adobe.com/api/v1/authenticate
2020/04/03 19:27:25.711189 [TVE] action=request type=Document method=GET url=https://sp.auth.adobe.com/api/v1/authenticate
2020/04/03 19:27:25.932769 [TVE] action=request type=Document method=GET url=https://oauth.xfinity.com/oauth/authorize
2020/04/03 19:27:26.165386 [TVE] action=request type=Document method=GET url=https://login.xfinity.com/login
2020/04/03 19:27:26.165429 [TVE] action=auth_domain domain=login.xfinity.com
2020/04/03 19:27:26.557315 [TVE] action=wait_for_page
2020/04/03 19:27:29.721813 [TVE] action=request type=Document method=GET url=https://oauth.xfinity.com/oauth/authorize
2020/04/03 19:27:29.912649 [TVE] action=request type=Document method=GET url=https://sp.auth.adobe.com/adobe-services/oauth2
2020/04/03 19:27:30.953032 [TVE] action=request type=Document method=GET url=https://login.discovery.com/v1/oauth2/authorize/callback/adobe
2020/04/03 19:27:31.523361 [TVE] action=request type=Document method=GET url=https://watch.hgtv.com/watch/hgtv
2020/04/03 19:27:31.935465 [TVE] action=authed
2020/04/03 19:27:31.935488 [TVE] action=wait_for_page done=true reason=auth_finished
2020/04/03 19:27:31.936709 [TVE] action=cookies num_domains=3 num_cookies=20
2020/04/03 19:27:32.330178 [ERR] Could not start stream for TVE-Comcast_SSO ch6104 HGTV: TVE: 403 Forbidden: Access to the requested resource path has been forbidden: [Authorized Networks: None] [Authorized Products: None].
2020/04/03 19:27:40.123551 [TVE] action=set_cookies domains=1 cookies=13
When i go into my TVE Xfinty tuner, and rescan that channel.
So, i disabled HGTV from Xfinity and enabled it on my Philo TVE tuner, also set Philo as higher priority tuner now, and it works fine for HGTV.
So, seems to be a Comcast/Xfinity login issue .
Ok im using optimum. May have to get a philo account
Does it work on hgtv website?
For me, using Xfinty login on HGTV site for the live tv stream....YES.
403 errors are indicative of authorization issues, and usually mean the problem is with the networks' backend, not Channels.
Well, Philo creds work, Xfinity does not.....in Channels...
both work on the HGTV website.
HGTV is working on my Xfinity
Its back working now. Thanks!
