Is there a way to get a show hidden channel toggle in the guide? For example, I want to hide movie channels, but I can show hidden channels and they will pop up. Something quick and easy.
Can you be more explicit/verbose about your request, please?
Are you saying you want some channels to be generally hidden, but if that channel is airing a movie, you wish to be able to select an option for movies on the hidden channel to be shown?
If that is the case, then you need to explore Channel Collections:
Yes,
Similar to how it currently is All Channels, HD, Sports, Etc. I was wondering if there could be one called Hidden Channels.
With Channel Collections, there could be.
Could you describe what you’re currently trying to accomplish, rather than asking about a feature to be created? This will help answer your question better.
He wants to hide channels, but have a way to show all hidden channels when needed.
Another user made a good suggestion about collections.
