Hide channels on Settings Page
This function works, however the return automatically goes back to the top of listing. Would rather see it stay in listing position at the point of change, so that one could continue reviewing the list.
Additionally, I would find it easier to make these changes on the “All Channels” listing (full icons). Currently, you can add to favorites here, why not add the hide function.
Second that. Would think this better fits on the “All Channels” screen. Makes more sense their to me.
Perfect on both changes.
Thanks for the feedback!
Both methods for favoriting/hiding channels work great. Thanks, the app is getting easier and easier to use.
I like this feature but can you make another section/line for “available channels”? As when you hide channels, the number of channels hidden are deducted from the found channels number. I would like that to remain constant as I use it to track to see if any new channels have been added or old removed. The new second (available channels) line that I’m requesting would show the channels the total I of channels un-hidden. A Favourited channel should not affect this total.
Further can you add a feature where new channels that have been added through a scan are highlighted so the user can be aware as this is not that easy, for me at least to notice. Also for it to be intelligent enough to un-hide channels that have had other channels move on to them, as here in the UK there was a big reshuffle and new addition of channels for the Olympic coverage.
Thanks
Good eye! That’s a bug, the number of available channels should not decrease as you hide channels. Will fix for the next beta.
