Hiding channels
Is there any way to get this as a client setting? We have client settings for almost everything but i can't turn off the ability for the client to hide a channel. I have an elderly relative who uses the app and they somehow with long press hide a channel once every month or two. Its a painful process to unhide. Thanks!.
Have you tried the Kiosk Mode?
This :point_up_2:
Yeah that has nothing to do with it
Even in kiosk you can accidentally long press and hide a channel…no fix from server side and hard to find to fix
An I missing something?
ok, that's not in there.
The only way to remove management completely is to put it into Kids Only Mode. But that's not what you want.
We'll look into adding settings for disabling management on its own.
