Hi,
I have a QNAP TS-670 Pro with DIY upgraded 8cores Intel CPU, i7-3770S CPU @ 3.10GHz and 16GB RAM. I have been using this NAS for 3 years, it rarely spikes more than 50% CPU and average temp is at 43c. After running the new Channel DVR for a week; now, everytime, just 2 minutes after any recording starts, NAS’S CPU spikes up between 50% to 70%, and temp goes as high as 67c. QNAP OS would auto-shutdown the system if it reaches 70c. The fan would go wild and noisy to keep the system down. The CPU would kind of tone down after 40 to 50 minutes of recording.
First, I want to understand what sorts of background task is Channel DVR doing to spike high CPU. Is it doing any encoding. Before Channel DVR, I used to have Plex DVR to record shows at the same time (Now, I stopped the Plex DVR recording completely right after I enable Channel DVR. So, it’s just Channel DVR doing recording alone), and Plex DVR CPU makes my QNAP NAS overall CPU around 7% with temp around 48C.
2nd, am I configure Channel DVR incorrectly? Is it doing any encoding in the background? Plex DVR recorded the TV shows directly from HDHomerun Extend without doing any conversion, therefore, the file is always in .ts format. I noticed Channel DVR record the shows in MPG. Is it why the mpeg file conversion causing high CPU? or something else? Is there anyway we can lower the CPU utilization? To have QNAP NAS to reach close to 70C everyday would make the Channel DVR unusable for me. I cannot afford to have my NAS to be shutdown at anytime.
Right now, I do not even dare to try Web Player while it’s doing recording because it would stress the CPU to the max.
Please advise any possible solution.
OSQNAP TS-670 Pro
Linux
(kernel: 3.12.6)
CPU
8 cores / Intel® Core™ i7-3770S CPU @ 3.10GHz
load averages: 0.25 0.46 0.52
RAM16.72 GB
78.8% free
Thanks
Rog
