channels-dvr process is using ~25% CPU when idle
This is happening on 2 of 3 Channels DVR docker containers.
All are at version 2021.07.29.2129.
1 uses an HDHR Prime source and shows ~25% CPU
2 uses a Pluto m3u source (Pluto Docker for Channels) and shows ~25% CPU
3 uses a TVE source and shows ~1.5% CPU
I have shut down and restarted the containers. No help.
Now all 3 containers are doing it.
Here's the Synology Resource monitor showing 2 & 3
UPDATE: It's not just in a container. I migrated #1 to the new Synology DSM 7.0 package and I'm seeing the same CPU usage.
Diagnostics submitted from #1 2fb51a29-ca38-455b-a773-4446929ca413
Diagnostics submitted from #3 15773beb-2508-405e-9d76-cff6357117df
