Hi,
I experience high latency (200-400ms) frequently. Speed is ok (300-400mBit/s). I have a problem when I try to skip ahead or back. It takes FOREVER.
When I have low latency (4-20ms) skip works great.
I have Google wifi and amazon fire TV 4k.
Once, I restarted just the fire stick and latency dropped to 4ms for a couple of days. Then quickly crept back up. I have tried restarting the fire stick several times again without any luck. I did a factory default on amazon fire stick. No success.
I Restarted Google wifi and had no improvement.
I have determined the correct sequence is restart Google wifi, then restart amazon fire stick. This has worked the two times I've done it but it only fixes the problem for a day or two.
I've read some negative reviews about Google wifi latency and am willing to replace it if that is the problem.
My question is, does anyone know if Google wifi or amazon firestick is the culprit? I will happily replace whichever hardware is the problem.
Doug
