Home Assistant Integration
I added this to my HA:
However it seems you can only add one instance/entity? Has anyone gotten more than one to work I am trying to monitor two channels instances for testing/comparison.
This integration is very old and is only configurable via yaml. You can add as many instances as you want following the normal yaml array list pattern.
