Home Assistant - TV Guide
Hi. Is it possible to access your channels TV Guide via Home Assistant?
The guide xml is available via the DVR api. You can find specifics if you search. You’d then have to parse the data and do whatever you want with it. What were you envisioning?
I’m curious what your use case is. I might steal your idea :grinning:
Same here. I'm curious.
Watching this thread. :smiley:
