Have a Remote CDVR set up with a Tablo 4 tuner. This Remote CDVR is properly pulling in OTA channels into the guide. Both our Home CDVR and the Remote CDVR are connected to Tailscale and I can remotely access the Remote CDVR through tailscale. Now I want to integrate these remote Tablo channels into our Home CDVR. Where is this done? I am assuming Custom Channel(s) but I have no idea how to configure it. Not sure if each channel has to integrated separately or if somehow the "Tablo Source" on the Remote CDVR can be grabbed. Any guidance would be helpful.
This example was for a person wanting to limit bandwidth. If you don’t want to limit bandwidth, after you copy and paste the url remove bitrate=3000 at the end and replace it with codec=copy. Obviously insert your unique Tailscale ip where it says.
Boom! That was the magic sauce. Thanks Rice!
