Home Streaming Quality
I've been messing around with this on an ATV4K and trying different quality settings other than 'original', whilst this works there is a repeatable glitch every few seconds in the video (slight stutter). At first I thought this might be the transcoding on the DVR machine which is consuming a lot of resources but I found that there is barely any CPU activity whilst this is running - is that normal?
The DVR is running on an i7 5820k - CentOS. As a comparison, if this is at all relevant, the web transcoding runs smoothly and the ffmpeg processes are consuming much more CPU time.
Is there anything I can do to get the video playback smoother here?
We recommend using Original for in-home viewing. Why are you trying the other settings if Original works?
Can't say what would be causing the stutter and cpu usage issues without seeing the logs from the DVR and diagnostics from the app.
