How do I add peacock or philo to channels?
Hello!
I’m trying to figure out how to add peacock and philo to channels DVR. I have a subscription for both. It I just can’t get it. Any help would be grateful
I’d recommend reading the support article if you haven’t already. Peacock cannot be added as it does not support TVE. Philo can be, but you likely will not get 100% of the channels, only the ones that support TVE login with your Philo credentials.
Thank you
