How do I fix this?
2021/02/26 19:17:11.222785 [ENC] Starting encoder for Hope.Floats.1999.720p.BluRay.999MB.HQ.x265.10bit-GalaxyRG.mkv in G:\Streaming\file122-ip1xxxxxx\encoder-0-762058686 at 0 (0.000000) (encoder=h264_nvenc, resolution=688, deinterlacer=blend, bitrate=6000 segment_size=0.01)
2021/02/26 19:17:11.407241 [HLS] ffmpeg: file122-ip192.168.5.143: [h264_nvenc @ 0000000002868a80] No NVENC capable devices found
2021/02/26 19:17:11.407241 [HLS] ffmpeg: file122-ip192.168.5.143: Error initializing output stream 0:0 -- Error while opening encoder for output stream #0:0 - maybe incorrect parameters such as bit_rate, rate, width or height
If you're streaming at home, make sure Home Streaming Quality is set to Original so the server doesn't try to transcode. It seems to be set at 6mbps
Thank you I will try this. I am streaming on a NVIDIA Shield TV device - the newest tube one
This worked. Thank you!
