I live near two major TV markets between Baltimore and DC. I want to use the Baltimore OTA network channels for recording, but when I select a program in the guide it tends to pick the DC OTA channel even though I set up the pass using the Baltimore channel in the guide. I have tried deleting the pass and selecting the Baltimore channel in the guide but it keeps deflecting back to the DC channel. How can I create a pass using the channel I want instead of what Channels selects?
You can do this via the advanced pass settings that are available in the DVR web ui.
I have the DVR engine installed on a Windows 10 PC. I assume that's where I would go to access the DVR web UI, correct?
You can access it from any device on your local network. Just navigate to http://X.X.X.X:8089, where X.X.X.X is the IP address of your DVR server.
Thanks. I was able to edit each of my passes in the web GUI to specify the desired channels.
