I have 3 channels that we watch a lot that I can't get with my xfinity TVE login (FOX, CBS & CW). The shows we watch are sometimes back to back and on at the same time, so I have a HDHomeRun Quatro for 4 OTA tuners and a HDHomeRun Prime for 3 cable card tuners.
I have both devices only seeing those 3 channels I can't get with my xfinity TVE login and I have set the HDHomeRun Prime above the HDHomeRun Quatro for tuner priority.
I have all of my passes set to start on time and finish 3 minutes over just in case. So, there is a possibility of a tuner conflict.
What happens if all the stations (FOX, CBS, CW) has a show on at 8pm that I have a pass for that is set to run 3 minutes long. Then CW has another show on at 8:30pm that I have a pass for.
What happens? What I hope happens is that the DVR sees that all 3 tuners on the Prime cable card device are in use, because all 3 shows have a 3 minute padding, and then uses the OTA Quatro tuner for the CW show that starts at 8:30pm. Is that how it is suppose to work? I haven't run into this use case yet but see it could be possible now since more of the CW shows my wife watches are coming back on.
Thanks for the help!
