I seen the update and got excited but I have no idea how to get PIP to work? I tried swiping down where you see the quick guide and the record button...I tried closing the app but I dont see the option anywhere.
Have you enabled it in the Channels app's settings? It needs to be manually enabled, as it is off by default.
ahhhhh I see it now...perfect thanks! but how do you turn it off?
nevermind I Found it
And, I had to update tvOS and Channels DVR manually, then do the enable in settings. After that it will appear when you get the bar that pops up to FF or RW that shows you the commercial breaks in the timeline. Its a little bubble above that bar. FYI, to end PIP you have to hit the TV button on the Siri Remote.
I suggest the folks at Channels create some demo videos for new features. It would help cut down on the frustration factor immensely. Thanks.
Agreed 100%
