How to enable audio description
Hello all,
Are there any users who use Audio Description?
I was wondering if anyone could describe the process to enable audio description when watching live tv, as well as recordings?
Blind user, using voiceover to navigate the app on ATV.
The app will generally try to enable AD audio when voiceover is enabled. But sometimes the tracks are not properly labelled.
To switch audio tracks, in the player you would swipe down to pull the quick guide down. Then swipe up to the tab bar, swipe right to switch to options. Then when you swipe down there are three columns for audio/captions/other. In the audio section you can select the secondary audio track and click to enable it. Sometimes it is labelled Spanish
