PIP is great, but the only way I can get back to full screen is by selecting a program in the guide. I would like to be able to return to full screen on the currently playing channel, without having to go back through the guide to find and re-enter the current channel in the guide. I frequently go into PIP to do a quick check through the guide, but then want to exit back to the full view.
Is there a command I can send with my Harmony Hub remote to return to full screen on the currently playing channel?
