How to fix Movie recording cannot Fix Match
How can I fix a movie that has the Wrong metadata ... Below is really Charlie's Angels 2000 ... Movie is named with year 1975. There is no way that I see to fix Incorrect match on movies am I missing something ???
Is the only way is to rename and move to imports ?
Charlie's Angels (1975) 2023-05-06-1744.mpg
That's the first option if you want to use the automatic matching feature.
Second option: manually edit all the metadata + artwork without touching the file itself.
Thanks I will use option #1 rename and move.
I see you withdrew your post CHdvrUser ?
Realized you were talking about a recorded (not imported) Movie right after I posted, so deleted my post.
I found out Editing metadata is not really a good option as it will still have the wrong year in the file ...
Now if Channels would rename it after Editing the metadata that would work.
